To many mushy peasFirst time I've heard that description of a pair of speakers. I haven't the faintest idea what this may mean?
Big t**s...?First time I've heard that description of a pair of speakers. I haven't the faintest idea what this may mean?
Apologies, you’re quite right. That’ll teach me for thinking I’d remembered.I have the Revel M16, they're a 6.5 inch bass driver rather than 8 inch surely?!
I was meaning a bit overblown, boomy if you like. But I see it really means coarse or untidy.First time I've heard that description of a pair of speakers. I haven't the faintest idea what this may mean?
Both Audioholics' and ASR's measurements show an exaggerated low end (bump):I was meaning a bit overblown, boomy if you like. But I see it really means coarse or untidy.
Untidy is good. Not smooth, tapering bass, but a bit untidy sounding. Trying too hard.
Nothing to do with blouses!
Thanks! I’ve not completely lost it then? My hearing that is.Both Audioholics' and ASR's measurements show an exaggerated low end (bump):
https://www.audioholics.com/bookshelf-speaker-reviews/revel-concerta2-m16/measurements
That doesn't surprise me. I've been checking the stocks of the UK DIY speaker companies and the 8" are listed as woofers not mid-bass speakers. There are a number of good mid-bass units with 145mm cutouts, which is a standard. The OD ranges from 165mm to 180mm. Some very good ones from Scanspeak, SB and Vifa-Peerless. They seem to have chosen this size for their flagship mid-bass ranges like Revelator, Illuminator, Sartori etc. costing hundreds of pounds.I have the full set of 1990s Goodmans Maxim, Mezzo and Magnum with 5”, 6.5” and 8” bass drivers respectively, and all the same tweeter. The Magnum sounds the best. Make of this what you will!
8" woofers were all the rage in the 1990s, in fact from KEF onwards, but 6.5" to 7" seem to be the current favourites.
With this in mind, how about a D'Appolito layout with two slightly smaller mid-bass drivers? Complex to DIY, I would imagine, but seems to offer some advantages. Some of the nicest sounding speakers I know use multiple smaller drivers for mid/bass rather than one large one.There are two reasons for using a 5" to 6.5" mid-woofer:
• the most important one is directivity matching - a larger diametre driver will have narrower directivity than a smaller one and that will produce a dip in the crossover to tweeter region off-axis (horizontal)
• the second reason is (narrow) baffle width and WAF - no WAF, no sales
Sure - many nice MTM. In my case I'm trying to keep things simple with a 2-way. But MTM effectively gives you a "larger" bass unit so better bass. Popular way to do it. Does cost more in mid-bass units, though.With this in mind, how about a D'Appolito layout with two slightly smaller mid-bass drivers? Complex to DIY, I would imagine, but seems to offer some advantages. Some of the nicest sounding speakers I know use multiple smaller drivers for mid/bass rather than one large one.
Not only more bass extension and less low-end distortion but also higher sensitivity and better directivity characteristics.Sure - many nice MTM. In my case I'm trying to keep things simple with a 2-way. But MTM effectively gives you a "larger" bass unit so better bass. Popular way to do it. Does cost more in mid-bass units, though.
...including Living Voice, for example...With this in mind, how about a D'Appolito layout with two slightly smaller mid-bass drivers? Complex to DIY, I would imagine, but seems to offer some advantages. Some of the nicest sounding speakers I know use multiple smaller drivers for mid/bass rather than one large one.
24"x12"x12"? That's about 40 litres internal. That's big. The problem with going big is that the cabinets resonate more and more and need complex bracing etc. Not to mention the space taken up. I presume he means sealed box, like they used for the KEF B200 and B139. It would need a large bass unit 8" up.... he feels the sweet spot for cabinet design and he mentions quality bass is 24 by 12 and 12.
I thought about that and this seems to be an old application for some of the well researched BBC designs.
I was just looking up threads on the B200 this morning.I would suggest that 8" is the best compromise size between extension and cabinet size . My preference is the SP1039 KEF 200 which is what is in my KEF 103 Reference speakers . KEF in the 103 got round the larger cabinet being resonant by using and internal metal frame and stick on pads seems to work well but they are a little heavy .
