Best speakers for low bass in small space
MBDK72
77
21
28
Hi. Can you suggest what the best speaker design is best suited to give deep, low but tight bass in a small space? By small I will say, 4m x 4m. Are we looking at a small ported standmount or larger driver in a sealed box? Discuss.
rdale
2,726
1,680
178
Gran Canaria, Spain
Richard Dale
I think the best way to get great bass in a small space is with a pair of small subs such as REL Tzeros with small standmounts.
CnoEvil
Legend Wammer
9,863
9,927
Northern Ireland
I agree.
It's tight with a £1k budget....but some second hand original LS50s, or Q Acoustics Concept 20s/3020i, along with a small Sub or two from BK might be doable.
Nopiano
9,647
8,052
Monmouthshire, Wales
Sixty or more years ago I recall that corner enclosures were a thing, mostly home-made or kit designs. Today, as long as you can position them optimally then some slim floorstanders might work well, as 4 metres is not a bad dimension. If the room is literally square then other problems might arise, as square rooms are far from ideal.
Reactions: MBDK72
tackleberry
4,120
Leeds..ish
I was gonna suggest those actually. Incredible bottom end on those for their size. I heard those years ago and asked the guy where the sub was!!
Reactions: Lowand
jobseeker
645
389
Madeira Island
4m x 4m is bigger than any music room I’ve had since 1980. I have used many floor standers of various types and sizes very successfully, bass-wise, so there is a big choice out there, depending on your preferences, room arrangements and budget. My current speakers are Audio Physic Tempo 35 in a 3.95 x 2.85m room.
Reactions: bigrod and MBDK72
uzzy
Grumpy Old Git
8,537
4,585
NN38TA Northampton
The room is square - not good. As to small speakers with a decent bass the Kef Meta reference 1 may do the job if you have £7k burning a hole in your pocker (reviewd this month in Hifi World). At real world prices though the Totem's mentioned above are worth a listen - but second hand if they are not too big something like the IMF super compact (3 way), or B&W DM2A may be to your liking (or not)
aiden.b
