Big speakers and suspended floors
G
Just had a brief moment of panic, I'm moving house soon and the new place has suspended floors. I've been living with concrete floors now for at least 14-15 years.
Anyone using big Tannoys in buildings with suspended floors? Am I concerned over nothing?
No neighbours to annoy but I'm worried about boominess.
bandit pilot
Comfortably Numb
14,388
2,872
North Nott's
Rick
Just had a brief moment of panic, I'm moving house soon and the new place has suspended floors. I've been living with concrete floors now for at least 14-15 years.Anyone using big Tannoys in buildings with suspended floors? Am I concerned over nothing?
It will be a case of suck it and see Tom. You might get lucky, or we might see big Tannoy's for sale soon. :D
themadlatvian
7,005
125
Huddersfield
Rick is bang on - don't panic yet. It all depends on the resonance frequencies of the joists, how well braced/damped they are, the dimensions of the room and the size/depth of the space beneath the floor. You don't of course want a floor to be freely flexing all the time, but I have known suspended floors that have been very successful with large speakers with extended bass response.
Steve (MVJ) struggled with this for years with his beautiful B&Ws, but I think that was caused by the unusually large cavity below the floor of his music room.
graham67
3,776
1,048
HI Tom,
I think you should be fine. I have now moved my GRFs to an old house with rattly suspended floors. And other than a bit of vibration transmitted to the floor the wheeled feet, there appear to be no obvious problems. And in their new bigger room, they now sound great.
If you are concerned, big slabs of 30mm or 50mm granite underneath are good as they create a nice stable level base as they are so damn heavy!
For smaller speakers on wobbly floors, Townhend suspended speakers stands are brilliant but I dont think they come in Tannoy size :) . But probbably due to their mass, the tannoys seem fairly immune to shaky floors.
G
Thanks guys. Useful reassurance. Glad to hear Graham you got a better location for yours :)
steelhull
255
3
Oxford, , United Kin
Mike
Hi Tom
I have large speakers in my first floor listening room with a bouncy floor and lots of boom in the room below. I fitted Townsend stands and there was a big improvement in the bass, much cleaner, and my wife was much happier!
i think that Townsend will build to order but obviously see how you get on first.
Mike
GR1
461
Studiospares and others have Isolation mats and Anti Vibration mats which will help/fix any problem. I would wait for any problem to arise before worrying about it.
G
geoffp67
large concrete paving slabs should help with boom IF needed. One may suffice, no reason not to use a few though :)
Or try standing speaker on a diy sandbox, wooden box with a couple of inches of dry sand in it
Sticking everything together with blu-tack is usually effective too.
I'd always try the very cheap solutions before going mad with the plastic
graham67
3,776
1,048
Thanks tom, they were all wrong in the last too small room werent they? But in their much bigger room they now sound good. :)
catcando
1,310
32
Cambridge
Gregg
Tom, there is a sensible fix, before you move in. Get 15mil plywood, and cover the room. Glue and screw it through the old floorboards, to the joists. You will have a very solid floor, for a small outlay.
avinunca1
1,335
139
Shrewsbury, UK
Michael
If you have wooden floors of course you might prefer to make a feature of them by sanding and Osmo oiling them - luvly
josst
160
22
London, , United Kin
Joss
+1 for the Townshend solution. He has even made stands for monster JBLs.
There is a picture of mine in my OBX-R2 For Sale thread. Simply, they work, and the benefits are not subtle - not only a complete absence of any hint of boominess in the bass but improved transparency, timing and punchiness across the whole frequency spectrum.
hifinutt
16,566
4,862
midlands , , United
phil
My Westminsters sit on a very springy wooden floor without any problem.
yes indeed , those monsters sound gorgeous !!
have no fear tom
I have big summit x and suspended floors and no probs
Andy831
1,100
64
Hebden Bridge
Andy
I can only speak for myself Tom but I have largish Tannoys, timber suspended floors and a rather large cavity below the floor and have few if any problems at my listening levels in a smallish room.
Purite Audio
6,850
41
London, UK
Keith
I have a cellar here underneath a suspended floor, and I am positive it contributed to a huge bass suck out, I would acoustically measure the room when you are settled.
Keith.
AmDismal
9,277
134
I was going to suggest just this, although I think I'd just screw it, as gluing is a bit drastic. You could also add mass - just lob in some hardcore underneath the floorboards. Won't look tidy, but will reduce those nasty resonances.
