Blu ray or another DVD player?
goomer
835
9
Suffolk
My Pioneer DV-868Avi seems to have spontaneously given up the ghost, with the buttons no longer causing anything to happen except a slight juddering noise from within. I'm going to have a look inside the Pioneer later today, specifically at the mechanism which is I think the cause of the noise in case it is something simple that even I can fix, but I think I am looking at the possibility of replacing it outright.
So, do I get another DVD player (a s/hand Pioneer 989) or do I plump for one of these new fangled blu ray devices of which I have heard speak? TV is an HDMI equipped Pioneer plasma which is used exclusively for playback of spinning silver discs (no TV aerial connection to worry about), sound is at present provided by a Yamaha 5.1 amp into a mixture of 5 Epos and Acoustic Energy speakers. This system also acts as source of CD playback downstairs so gets used in 2 channel mode for a fair bit of the time and I have been contemplating dumping the surround sound entirely, and just replaying films via a Quad 44/405 that I have sitting idle. The question is therefore what blu ray players offer brilliant multi region DVD playback (I assume that is quite a lot of them) via HDMI, are excellent on CD/DVD/blu ray playback via their RCA phono outputs, and which are ideally silver in colour (to match the TV connection box)? Budget is as low as is realistically possible for comparable (though ideally better - I don't ask much...) performance to the 868Avi?
luckysim0n
1,865
570
Simon
oppo all the way pick them up second hand for reasonable money too I actually sold my Audiolab cd player as I could not distinguish any difference in cd playback
goomer
835
9
Suffolk
Oppo looks good but a bit more than I really want to spend at the moment, to be honest. I was hoping for nearer the £100.00 mark - don't mind s/hand and older but tried/tested technology.
themadlatvian
7,151
123
Huddersfield
I picked up a minter Pioneer DV-LX50 here on the Wam over Christmas for £75 - super machine which would replace your model very capably, if you can find one.
goomer
835
9
Suffolk
Thanks - that looks like the sort of thing, so will add to my search list. My 868 is definitely faulty beyond my limited repair abilities, unfortunately, so will stick a wanted ad up in the classifieds.
hcanning
80
58
23
Berkshire
I see no reason not to take this opportunity to upgrade to Bluray, personally. I'd suggest a Panasonic BDT130 for about £75 as it's an excellent device but perhaps the analog 2ch phono outputs won't be quite as "sparkling" as an older high-end DVD unit. In reality with anything less than somewhat high-end hifi, you probably won't be able to detect any negative difference.
highfidelity
47
My Pioneer DV-868Avi seems to have spontaneously given up the ghost, with the buttons no longer causing anything to happen except a slight juddering noise from within. I'm going to have a look inside the Pioneer later today, specifically at the mechanism which is I think the cause of the noise in case it is something simple that even I can fix, but I think I am looking at the possibility of replacing it outright.So, do I get another DVD player (a s/hand Pioneer 989) or do I plump for one of these new fangled blu ray devices of which I have heard speak? TV is an HDMI equipped Pioneer plasma which is used exclusively for playback of spinning silver discs (no TV aerial connection to worry about), sound is at present provided by a Yamaha 5.1 amp into a mixture of 5 Epos and Acoustic Energy speakers. This system also acts as source of CD playback downstairs so gets used in 2 channel mode for a fair bit of the time and I have been contemplating dumping the surround sound entirely, and just replaying films via a Quad 44/405 that I have sitting idle. The question is therefore what blu ray players offer brilliant multi region DVD playback (I assume that is quite a lot of them) via HDMI, are excellent on CD/DVD/blu ray playback via their RCA phono outputs, and which are ideally silver in colour (to match the TV connection box)? Budget is as low as is realistically possible for comparable (though ideally better - I don't ask much...) performance to the 868Avi?
Best Buy IMO is the Sony BDP-S790
goomer
835
9
Suffolk
Thanks, may well be picking one up later in the week. Does anyone know if the multi region DVD hacks for the Sony (where you program a learning remote with some special codes) actually work?
Chumpy
14,084
Good luck to all who meaninglessly prefer potentially superior BD to DVD etc.
Great video-film etc is great whatever the format.
Enjoy your choices.
goomer
835
9
Suffolk
Right then. Have now picked up a BDP-S760 for £40.00 and have it connected as follows:
HDMI > TV;
Coaxial dig. out > Yamaha amp DVD input for movies (surround sound 'On' on the amp);
Stereo L/R analogue RCA > Yamaha amp CD input for music (no surround 'On').
Is there anything I need to do/check in the Sony menu to optimise things for stereo sound quality or if things are set to auto, can I assume that all should be okay?
C
Crazytrain
Might be worth checking which dac is better for stereo replay? The one in the sony or the yamaha.
highfidelity
47
Right then. Have now picked up a BDP-S760 for £40.00 and have it connected as follows:HDMI > TV;
Sounds best in mch connected by HDMI
roob
912
5
stoke-on-trent, ,
andrew
Best to connect to an AV amp using coax thats how I have my Sony BR player connected but it is only used for film duties.
Creedy
