burning hashbrowns in stainless
Anniecl20
4
3
3
I used to be able to make perfect hash browns every time. Brown, crispy, perfectly done. This was in a 12" cast iron skillet on on electric stove.
We got a gas stove and bought expensive stainless steel cookware. I have now ruined hashbrowns five times in a row and cannot figure it out.
They stick and burn just a little bit, which prevents heat transfer and makes them mushy and gross. I am using peanut oil and never turn the burner past 2 out of 10. I let the pan preheat slowly - at least eight minutes - use 2 Tbsp of oil (as before) - and put the potatoes in when the oil just starts to smoke.
What am I doing wrong?
lostwin
Tinker Bod
2,472
2,468
Folkestone, Kent
Can’t you still use the iron skillet? I would have thought that is providing very even heat distribution whereas the new pans conduct better but unevenly.
lostwin
Tinker Bod
2,472
2,468
Folkestone, Kent
Love a good hash brown, I now cook them in an air fryer, which is quite effective. Do you have a favourite brand or even make your own?
ESK
1,693
387
Edinburgh, , United
Euan
Could be your pan is to cold to start with.
Heat it over a medium heat for 2 to 3 minutes before adding the oil.
Add a bit of your hash to the pan and if it doesn't sizzle then it is still too cool.
Add your hash and then leave it to seal then flip.
gintonic
Noise, distortion & faff
6,832
1,635
no where
simon
edit: rapeseed (or 'vegetable') oil can cook at higher temperatures without smoking
it can still smoke at higher temperature
if the oil smokes is it too hot?
possibly - depends what you are cooking and how long it smokes for.
If i am frying a bavette for example, i will get my pan smoking hot (no oil). I will either then add a drop of oil to the pan - fry the steak for 2 mins per side - rest for 5.
I suspect for the OP - too much oil, at too hot a temperature. Shouldn't #browns be deep fried? We buy them ready made and frozen and cook in the oven.
zari212
thank you very much i will try it right away
awkwardbydesign
Perfect, apparently.
10,417
2,184
And stainless doesn't transmit heat very well, which is how our pans can use a stainless handle without burning our fingers. And when welding stainless, one has to be careful not to distort the metal by trying to weld in one long run.
gintonic
6,832
1,635
no where
simon
my fastest heating pan is stainless
aiden.b
