Burson Soloist SL at Audiologica
Audiologica
Audiologica
1,308
Horsham
Richard Santiago
A cut-down version of the classic Soloist - a real bargain at just £499 including delivery
http://www.audiologica.co.uk/burson/burson_soloist_sl.html
01403 336 339
A Focused Musician
The Soloist SL is a concentrated version of our award winning Soloist. Its DNA is identical to the Soloist and it exists for one purpose only. That is to be one of the best headphone amplifiers in the world.
Just like the Soloist, the Soloist SL is completely discrete in design. (IC free). It features the same 21 component Field Effect Transistor input stage and the same discrete power supply network which brought popularity to the original. Assembled with the same high end components and operating in pure Class-A, the Soloist SL carries the same sonic signature which has been described as the utmost in organic and transparent. At 14cm * 8cm * 21cm it sits elegantly on any desktop. But with 2 Watts per channel into 16ohm, the Soloist SL is one of the most powerful headphone amps in the world. It is capable of driving most if not all headphones to their full potential. Coupled with a 2 level gain switch, it offers infinite flexibility. The Soloist SL is housed in a refined and precision folded 2 mm aluminium casing that is unmistakably Burson. This case also works as a singular heat-sink for the entire machine ensuring stable and optimized performance at all times. This case really puts the conventional 1 mm folded steel case and generic heat fins to shame.
Measurement
Input impedance: 36.5 KOhms
Frequency response: ± 1 dB 0 - 50Khz
Signal to noise ratio: >96dB
THD: <0.03% at 30ohm with 1W ouput
Channel separation: >73dB
Output power: 2W at 8 Ohms
Input impedance: >8K Ohm @ 30 Ohm, 1W
Output impedance: <1 Ohm @ 30 Ohm, 1W
Power dissipation: >20W, internal, regulated power supply
Inputs
2 x gold plated RCA (line level input)
Outputs
1 x headphone jacks 6.35mm
Package Content
1 x Soloist SL Headphone amp
1 x Power cable
1 x RCA pair input cable
1 x User Manual (including 24 months warranty registration information)
General
Weight: app. 2.5 kg
Colour: silver anodized aluminium
Dimensions: 140 mm x 80 mm x 210 mm
tomasz1500100
