I have some B & W DM 4s which I like the sound of, but they are a bit tatty looking. The main structural material of these is chipboard, if I try and lift the veneer of with a view to re-veneering them, the surface underneath is very dry and crumbly. Also the state of the chipboard is causing some of the screws to work loose, particularly on the tweeters.
Is building new cabs from top grade ply and veneering in a finish of my choice going to change the speakers sound drastically? Obviously the dimensions/volume will remain the same, I simply want to improve the build quality and appearance of these nice sounding speakers without buggering up the sound.
Mike
Mike
