Question Cambridge Audio CXA81 & Azur 851A
A question.
FizzyPickles
137
192
Lance
Is anyone familiar enough with both to give me some idea of the different sound characteristics I might expect from them? Any major pros & cons, any speakers they each play particularly well or poorly with and why one might choose one over the other?
Strider
Nothing to see here
5,308
2,684
somewhere or other
Mark
I'll be brutally honest here, after my beloved Primare I30 bit the dust early this year I was amp searching and after reading relentless reviews I bought the CXA 81, I kept it for a month and I had to return it.
I found it to be powerful but lifeless, the bass was lighter than expected and it was rather 'shut in' meaning small image due to the rolled off treble and upper mid lack of energy, I think Cambridge Audio were aiming for a 'grown up' sound but unfortunately robbed the amp of get up and go.
I was gutted because it ticked every box I was after and had great reviews, build wise it was excellent and looked good too.
Both my son and Mrs commented that it "sounds flat", they like quite eclectic music as I but it wasn't for us.
I also had an Arcam SA 20 which was in a similar vein to the CX but had better frequency response.
I'm not one to knock kit because it depends on synergy especially speakers, if your speakers are 'bright' (B&W or MA) it might just be what you're looking for, try before you buy and see if Richer Sounds have one that they'll let you demo, they're really good people to deal with.
Reactions: FizzyPickles
jinj
18
14
8
What did you opt for and are you happy with it
FizzyPickles
137
192
Lance
Funny you say that, a friend of mine and big CA fan described the CXA 81 as 'laid back' and it's smaller cousin the CXA 61 as a bit more 'lively'.
I heard a Primare 125 last year, hooked up o some Sonus faber Lumina III's. It sounded exquisite but a little outside of my price range for now.
The Cyrus One range has also been mentioned to me as a good 1k all-rounder.
One of the reasons I considered the Cambridge amps is because I was led to believe that they would play fairly well with a whole range of different speakers. I have Monitor Audio Bronze 100's at the moment - I guess they could be considered 'bright', they're certainly detailed in the upper range.
What did you go for in the end?
FizzyPickles
137
192
Lance
Can’t speak for the 81, but I think the 851 is a decent amp and wouldn’t describe it as above. Again depends on your speakers….
How would you describe its sound profile?
I'm running Monitor Audio 100's at the moment which don't get the credit they deserve imo. Quite detailed, bit of bottom thump. I really want to move on to some Sonus Faber Lumina's but that wont be until next year.
Strider
Nothing to see here
5,308
2,684
somewhere or other
Mark
H
I listened to a few amps including a Hattor passive pre-amp and a Nord Class D, incredible power, detail and control, however I ended up with a Rega Elicit-R, not quite the heft of my previous Primare but it is so even across the board, detailed yet not harsh, good bass weight and lovely liquid midrange.
One thing that the Rega does so well is the way it conveys the ebb and flow of music and its What some refer to a 'fast' meaning it has that ability to keep your feet tapping.
The Primare painted huge masterpieces with broard brushstrokes and phenomenal slam where the Rega is more like a fine watercolour painted with delicat strokes but painted with bright vibrant colours.
The Rega works well with my ProAc's, Dali's, Monitor Audio S1s so it's not a one trick pony.
Downsides? It runs hot and it's also thirsty being Class A..
Strider
Nothing to see here
5,308
2,684
somewhere or other
Mark
I've a pair of Monitor Audio S1 Silver, superb speakers that are detailed but not at all harsh, they are pretty even across the board amd have surprisingly deep bass, great for rock and jazz.
Rockchild
Formerly Radiant Red 🎶
10,009
12,873
Launceston UK
Jonathan
H
The Rega is a class A/B but the transistors do get quite hot.
Strider
Nothing to see here
5,308
2,684
somewhere or other
Mark
From the horses mouth:
"The output amplifier used in the Elicit-R and Brio-R was born after extensive research by our engineers to develop a low source impedance emitter follower Class-A driver stage. This is based around a complementary pair of 150w Sanken Darlington output transistors."
And like you said it does run pretty hot!
Rockchild
10,009
12,873
Launceston UK
Jonathan
Yes, driver stages but the design is A/B but it’s a very good amplifier.
I borrowed one a few years back. Impressive.
Strider
Nothing to see here
5,308
2,684
somewhere or other
Mark
Bloody Rega can't make up their own minds! :ROFLMAO:
Thanks, it took me a few days to see what the fuss was about and I've found that it really does need to warm up before it comes on song, its not harsh or flat etc but after an hour or so the sound 'blossoms'.
Rockchild
10,009
12,873
Launceston UK
Jonathan
Class A is often quoted on many amps but in the design principle it’s only the first 10w or so but a true class A like the Sugdens run REALLY hot 🥵
Many headphone amps run as class A or the amplifiers internal headphone amp.
Guitarlegs
