Can a laser damage a camera?
Valvebloke
Member
4,432
274
Didcot, Oxon
If it's CW then I'd be surprised if 2mW was enough. But if it's pulsed (i.e. mode-locked or Q-switched or some such) then it might. It would need to be focused down, but the camera's lens might well do that. 488nm used to mean Ar+. Some of the little air-cooled ones had powers of a few mW. But most Ar+ lasers were big beggars, ranging from several hundred mW up to 'large frame' ones delivering 10-20W. With appropriate focusing they would damage house bricks and would set fire to your tie unfocused if you were careless enough to dangle it in the beam.
VB
chrisB
11,029
210
The short answer -if I understood Valvebloke correctly- is YES.
Valvebloke
Member
4,432
274
Didcot, Oxon
Ah, then I hadn't made myself clear. For a 2mW CW laser the short answer is NO (I imagine - don't sue me if I'm wrong though).
This is a concert laser apparently. In one of the follow up comments someone points out that that may be anything from <500mW up to 40W (!!). In any case much, much more than 2mW.
VB
