Hello,
looking for advice on Cartridges for an Audiomods Series6 arm and a Garrard 301. I am using a bespoke Amp/PhonoStage built by Graham / Blackcat Audio. It has a valve phono and valve pre-amp before one of his chip amps and driving b&W 801 series 80.
I used to play a Denon 103R on and SME 309 arm on 301, this is the fist install of the Audiomods arm. But i am a clumsy bugger and broke the tip of the 103R. Once it had settled in i did love the sound of the 103r compared to entry range cartridges i had used before, like Ortofon Red
My question is within the 103R price range-ish (maybe i can push to one grade up) what other cartridges would you recommend and maybe would prefer the easier MM route and not even use my step up for a bit and most importantly i can get replacement tips relatively easily. i seem to break tips more regularly then i can afford. \
thanks in advance
DL
thanks in advance
DL
