Cartridge for Pioneer PL12D
monya
1,479
250
London, , United Kin
Robin
A mate of mine wants to resurrect this old deck he has. The motor works but the cartridge - a Shure EJ T2 is knackered. Anybody know of a cheap replacement that can be used. Apparently anything conforming to IEA according to the manual. Suggestions and where I can get it would be welcome as muggins here will probably be called upon to fit it. Which will be interesting as I don't have any appropriate tools.
RobHolt
942
30
East London
Rob
It should take a standard cartridge in the SME type detachable shell.
Standard recommendation for a budget cartridge is the Audio Technica AT95E which can be had for around £25.
An alternative is something like this which comes pre mounted on a shell and is pretty much plug, balance and play.
Ideally it needs aligning perfectly with a protractor but it won't be far out as supplied. Depends how serious your friend is about his vinyl and how much he has.
http://www.ebay.co.uk/itm/official-audio-technica-VM-type-dual-magnet-stereo-cartridge-headshell-AT100E-G-/360652914380?pt=LH_DefaultDomain_0&hash=item53f896becc
A
avole
Haven't touched my PL12D for a while, but the AT95E does fit and isn't a bad choice.
The only tool you need is a protractor, which you can download from vinylengine.
23joggler
