A lacquer/varnish of some kind. I've used clockmaker's lacquer in the past to protect brass parts from oxidisation. For example:so we have anodising for aluminium but what coating is used for brass?
in particular tonearm parts?
anyone know?
Then it may not be brass. Unprotected brass oxidises.no mate its not painted
Probably plated in that case - nickel or chromesorry i dont think you understand,its a tonearm mounting collar, it has a surface finish over the brass,its not paint but some king of coating all over.
ie like anodising for aluminium,its a typical silver tonearm colour.
Satin Chrome plated.a picture says a thousand words.
in the photo you can see the coloured finish has been rubbed thin near the allen bolt, you can also see its brass in the countersunk area of the right side allen bolt.
my question is what finish would be used to replicate this colour please?
