For Sale Cisco 2960 Network Switch
For Sale
vince1
176
3
Surrey
Vince
Cisco 2960 series 8 port network switch in good condition and I am including an ethernet to VGA cable to enable connection directly to your monitor to view & adjust settings as required. These little units are of commercial grade compared with those cheap network switches available and are vastly superior for minimising any signal loss & drop outs over your network whilst streaming etc. and do make a difference. £35 incl UK shipping
daccordimark
65
22
23
Huddersfield
Mark
Hope you don't mind but I'd like to clarify what that blue cable is.
It's an RJ45 to DB9 serial cable not VGA. To use it you need a serial port on your computer or a USB to serial adapter and terminal emulation software like Putty in serial mode. Once connected you can configure the switch via the CLI but it also comes with a web interface which is easier. It won't connect directly to a monitor.
Reactions: Strider
87mpi
Nardò
Hi, thanks for the info.
I will use web interface (Could you explain to me how to do it?)
Antonio
Strider
Nothing to see here
5,294
2,654
somewhere or other
Mark
Antonio
Hi there, to save you a little time, the blue cable is an RJ45 to 9 pin D Type serial (RS 232). Its used for configuring the switch and not a VGA cable.
Sorry, @daccordimark beat me to it!
puresse
