Clearaudio Champion Level 2 verses Michell full ORB
S
skyman
Considering a possible trun table switch. Michell full orb with SME V and Dynavector XVS-1. Same rig on a clearaudio Champion Level 2. Any opinions or experiences people??
Purite Audio
6,850
41
London, UK
Keith
I would have thought they would sound pretty much identical, try direct drive in place of the rubber band.
Keith.
S
skyman
I would have thought they would sound pretty much identical, try direct drive in place of the rubber band.Keith.
So...a starting point might be?
Purite Audio
6,850
41
London, UK
Keith
I owned an Orbe for best part of twenty years replaced it with another belt drive this time high mass without suspension,( which I preferred) bought an SP 10 direct drive which I preferred to either.
To the Op you really need to hear all 'possibles' in your system but with turntable Ethan is of course extremely difficult.
Keith.
pmac
14,225
299
I owned an Orbe for best part of twenty years replaced it with another belt drive this time high mass without suspension,( which I preferred) bought an SP 10 direct drive which I preferred to either.To the Op you really need to hear all 'possibles' in your system but with turntable Ethan is of course extremely difficult.
Keith.
So, why do you suggest that those two t/t's would sound "almost identical"
Is it because they are both belt drive?
pmac
14,225
299
Why would you think they would sound significantly different ,the Orbe's suspension?Keith.
You stated in post #2 that you preferred one belt drive t/t over another, due to different (or lack of) suspension :dunno:
Purite Audio
6,850
41
London, UK
Keith
The high mass deck was a TW AC, one of the best engineered turntables available the Orbe did sound a bit wobbly in comparison,
Keith.
pmac
14,225
299
So, why do you suggest that that the two t/t's in question should sound identical?
and, why do you recommend direct drive?
whizzkid
I told you it wasn't important
8,349
1,078
Earth 2
Slartibartfast
The high mass deck was a TW AC, one of the best engineered turntables available the Orbe did sound a bit wobbly in comparison, Keith.
And the AC sounded heavier? I'd stop now Keith that holes getting deeper.
pure sound
8,762
217
West Devon
I owned an Orbe for best part of twenty years replaced it with another belt drive this time high mass without suspension,( which I preferred) bought an SP 10 direct drive which I preferred to either.Keith.
I thought that you hadn't got on very well with the SP10 :?
Keith, what do you prefer about the Monarch (boutique Technics 1210) over the TW AC?
browellm
23,599
482
Stick around skyman, it gets better than this.
alright, it doesn't get better.
Purite Audio
6,850
41
London, UK
Keith
I think that what at the time what I perceived as a weakness was in fact a strength, perhaps if had persevered or tried another plinth design.
I really enjoy the solidity of DD .
Keith.
whizzkid
8,349
1,078
Earth 2
Slartibartfast
Stick around skyman, it gets better than this.alright, it doesn't get better.
Especially when all the dealers get involved, Sodders will be around soon.
