Adding compression with change the frequency spectrum - you're adding harmonics. i.e. distortion vs the original signal.
It depends whether the "remaster" involves working on the original stereo mix, or whether what's called for convenience "remastering" went back to the original multitrack tapes and remixed as well as remastered. If the former, then Mr Coco is substantially correct, although it also depends on whether the compression is done broadband which has a more limited effect on frequency distribution or multi-band which divides the audio band into 3,5 or 7 bands and compresses each band individually to get maximum energy out of the recording. That changes the entire frequency distribution of energy.
If the "remastering" has gone back to the original multitracks, then each track or submix, like drums, can be equalised and compressed independent of the other instruments, so should retain much more of the individuality of the instrument, although the sound will change as otherwise there's no point in doing it.
Remastering isn't always bad as modern tools can correct for things like pitch instability in early tape machines, or even, as in one Miles Davis recording, the tape machine was running at the wrong speed all though one recording.
S.
