Confused about "ball bearing" footers
Tim F
561
166
73
Bedford
I have original still points and some other ball bearing type footers. I believe the "science" is that these move a micro amount and dissipate vibration as heat. However I just can't see how this'd work (other than coupling to a smaller surface area like spikes). When you put a ball bearing, even a ceramic one down with a great deal of weight on it, I simply can't see how this would move. These in addition are not greased and therefore surely have more friction. So how are these "supposed" to work?
uzzy
Grumpy Old Git
8,239
4,100
NN38TA Northampton
Have to admit they never rocked my boat. I've tried loads in my time from sorbothane and blu tac to rubber and sponge and combinations .. but found the biggest improvement with an old amp I had with a noisy transformer was a house brick on top of the amp which reduced the noise of the transformer considerably.
I have seen magnets used with a plinth to "suspend" the plinth and seen others using washing machine antivibration feet on loudspeakers.
Whatever works for you is the answer but the only concern I have is I can buy a finely engineered atomiser for my ecig from China for less than £20 (Zeus and Dead Rabbit offerings) yet some of these ball bearing feet thingies cost a bloody fortune. Being a tight old git who is happy with the sound he gets from his system none of my hard earned pension will be going in that direction.
Reactions: Ears
Tim F
561
166
73
Bedford
I get the friction part however it’s like me trying to push a tank, it’s not going to move at all.
Tim F
561
166
73
Bedford
The Sonirity platform looks like two heavily damped boards, I do wonder how much difference the ball bearings are making (versus if these were spikes)
dillondwight
