Hey
I am running an active system made up of Majik -
DSM/3 streamer
6100 amp
Aktiv Cards
K400 speaker cable
M140 speaker (on Linn's own upgraded base plates)
The DSM is running the Bass Drivers and connect with the 6100 via a pair of Audioquest Yukon RCA.
Both DSM & 6100 are on the same dedicated double power socket, this upgraded as was the electrical feed back to the fuse box, ie no other devices on this ring main.
Oh by the way I am using Tidal & Qobuz for content.
So speakers are around 33cm from the back wall & 165cm apart (centre of tweeter to tweeter) and I am seated at around 190cm away (tweeter to ear). The wall behind my seating position is around 47cm from my ears..
Whilst I can say, to my untrained ears at least, the system sounds ok (SO. has been a life saver, with it switched off music was simply appalling) I am finding that it is still only certain music where I think "Yeah this is good" and usually only if playing at higher volumes, for example, Yello's Toy album.
'The problem i have' is still with the bass, for example listening to Dire Straits Money for Nothing or even Christine and the Queens, Chris album (Girlfriend) - here it sounds like the bass woofers out of phase or a low pass filter stopping them going any lower than I dunno let's just say 300hz.
Whatever the case it feels as though the bass woofer is doing very little with the majority of music. I don't know what for example m109's sound like but I'm imagining that's what I'm listening to so very often here.
Maybe its room modes working against me, SO. not correctly configured, my own bias, or simply that I'm expecting too much from the system I really don't know.
Then whilst my gut is telling me that what I have should sound somewhat better, I'm in the next breath wondering whether adding a 2100 amp on to the bass woofers would help 'fix the problem'..
... If not, then it would put me on track for a Selekt later, right? Then, maybe then, I might get the enjoyment that I'm currently thinking I might / should from a system at half the price.
I know i need to listen to other speakers with the same music to make a more informed judgement of what I have and or ask other 'music lovers' to come visit to give me their opinion before just throwing more money at it.
Cheers.
DSM/3 streamer
6100 amp
Aktiv Cards
K400 speaker cable
Cheers.
