Hello again,
As I mentioned in a previous post I've acquired a TD160 deck with a DIN connector. The DIN plug was somewhat corroded and in a bit of a sorry state so rather than buying a DIN to RCA adapter I've decided to simply swap in RCA plugs. I say 'simply', but the truth is I've never done any soldering before so want to make sure I don't make a right mess of this. So I have a couple of questions:
Firstly, is there a ground wire that was attached to one of the pins in the DIN plug (or the shell of the DIN plug) that I need to concern myself with? I've read elsewhere that the TD160 is grounded internally but I can't find any mention of someone who has specifically changed a DIN plug to RCA plugs on a TD160.
Or can I just chop off the DIN plug, strip the left and right wires and solder them each to an RCA plug?
Any other thoughts or advice on problems I may encounter or pitfalls to be avoided would be much appreciated.
Thanks.
Cheers.
Thanks.
Cheers.
