Resources for fidly bits
http://www.maplins.co.uk - The first port of call for many. I find them expensive and lacking in their range. They do have a few items of use though so always worth a look.
http://www.cpc.co.uk - Now part of farnell. I use them because they're down the road and I can go. Range is reasonable and price is good. Downsides are that the site is a pain to use and some items can only be bought in high quantities.
http://www.rswww.com]http://www.com]http://www.rswww.com[/url] - The daddy of them all. By far the biggest range with just about something for everyone, they even sell decent capacitors. Delivery charges are reasonable and they deliver quick style. Downsides; they only accept credit cards over the net and you may need to order high quantities.
http://www.rapidelectronics.co.uk - Similar to CPC in many ways. Not really for the audiophile but a good range and a good price none the less. Need to be dealing with them for six months before they'll post to an address that isnt the cardholders.
http://www.cricklewoodelectronics.com - Not bad, some good products, especially when looking for caps at a decent price, always worth a look.
http://www.hificollective.co.uk - High-end products, they aint cheap but they stock some exclusive products for those with decent back accounts.
http://www.audionote.co.uk - Still popular and have some decent products, worth a look.
http://www.wires.co.uk - If you want wire check here. A large range of, er, wires. Silver, gold, silver and gold, copper, silver with ptfe etc etc, always check here if you want wire.
http://www.iplacoustics.co.uk - Mainly speaker kits and components but Ivan does have a good range of caps, resistors and wire.
http://www.net-audio.co.uk - Specialise in CD clocks and DACs but they do have some other components to sell. Good for those looking to mod their older Quads. Always worth ringing though, Ive heard some good deals can be had.
http://www.audiocom-uk.com - Another CD specialist. They also stock some nice caps and resistors. Their own products are highly rated.
http://www.tube-shop.com - If like me, you like your valves, this is a good place to have a look. A good range of the most popular valves including some nos (new old stock) tubes.
http://www.watfordvalves.com - Dont think theres a tube they dont stock. Very popular with the guitar player and seem to sell only quality stuff.
http://www.ebay.co.uk - No seriously, lots of stuff to be had. If your looking for tubes etc always check out the international sellers (espec. the USA) they are much cheaper and Ive never had a problem importing.
Will add more later.
