DMN Reson Speaker Cable
Good Vibes
292
14
Croydon, , United Ki
Any thoughts......
Good or bad, in value and price for instance!
mikedefacto
4,110
16
Mike
The interconnects are very very good - not used the speaker cable yet though, but am considering it.
It's about 70 quid for a 3m terminated pair.
Leonopolis
90
Baveria, Germany
Leon
I've got 4 lengths of 2.5 metre DNM reson unterminated (was using them biwired) that I was thinking about offloading if anyone wants to try them, will listen to any reasonable offers.
Very transparent and detailed cables, just didn't suit my already bright set up.
ESK
1,679
340
Edinburgh, , United
Euan
Cheap, nothing fancy, good WAF. Made my amps run hot though.
Would rather save up and get something better.
From memory, I preferred a couple of the lower priced Chord cables.
mosfet
6,194
19
Surrey
Speaker Cable: High DCR likely to cause audible power losses and stuff up amplifier damping factor nicely. But subjectively you might like this difference.
Interconnects: I have used these, flimsy, but sounded fine. Occasional RF breakthrough.
Value: Piss poor when you consider you can buy the same 1/0.6mm equipment wire for about £3-£4 per 100m.
Draconis
73
New Zealand
Neil
I used these for a while, speaker cable was a bit blah, but the interconnects (bullet plug version) improved the sound of my ancient hitachi tuner no end. For the price they are they are bloody good value if you go along with the philosophy behind them.
JANDL100
18,786
4,814
Forest of Dean, Glos
Jerry
I've tried both DNM i/c and speaker cable - both are pretty "blah" sounding IMO.
Van Damme i/cs and Gotham speaker cable are substantially better, soundwise, IMHO. Cheaper, too.
nipponhifi
613
22
Uppsala, Sweden
Martin
Depends on the equipment you're using them with...
With solid state and dark / warm sounding amplifiers (Electrocompaniet for instance) they can sound really good.
If your system is already bright of stark sounding, they won't help matters however. Not because they are bright or stark; they just don't polish the turd in any way.
Great with DNM, obviously!
Martin.
Lefty
2,884
385
In your town
Tried the Bullet Interconnects. Very clean, direct and airy sounding but a bit undernourished in the midrange. An interesting cable certainly worth investigating.
Lefty
A
A.N.
i'm using them with my icon, brilliant for the cash, nice and natural, doesnt add or take anything away from the system.
DaveB
