Use identical ic's all the way thru the system, ( or, rephrased,do i need same type between pre and power as in the rest of the kit?)
Cheerschum, but, if im using a cheaper cable to link the pre and power, would it not degrade the sound?
Well in that case there lies the problem, cos im using a Chord silver siren ic twixt pre and power, and Nordost blue heaven, (which to my ears is a millilon miles better, and explains the reason why im getting another to use with the X10v3) for cdp to pre.Well i'd always have the superior i/c in betweem source and pre . If the i'cs are the same brand i can't see a problem . Throwing extra quids so you have the same will improve things but not night and day so i save your dosh
Sorry IHB. I think i should have said i dunno! I use Van den hul 102 MKII AND MKIIIthat is some 20 years old and have never even thought about how it performsHmmm...yes...no....maybe................lets explain the thoughts behind those suggestions then boys eh?![]()
yep thats the way ah ha ah ha i have it....ah ha ah haAs the source is the most important part of any set up, you should have the best inter connected to that.
