Answered Do passive preamplifiers benefit from low capacitance interconnects?
This question has been answered.
Strider
Nothing to see here
5,548
3,358
Slightly damp but willing to get wet.
Mark
Some of you know that I'm looking to build a passive preamplifier and I've already bought some bits and bobs to start me off.
I currently have two passive preamps feeding a pair of Extron class D monoblocs with varying success:
The Little Bear preamp has both balanced and unbalanced inputs and outputs, the Tisbury preamp II is unbalanced only.
The Little Bear preamp although cheap is rather good having a clean sound without any apparent nasties, the Tisbury however is a little bit soft and lacking in upper mids, it seems to have an odd issue that stereo balance isn't linear but shifts around depending where the volume control sits.
The Little Bear preamp has a 50k pot where the Tisbury preamp has a 10k stepped attenuator - would the difference in input impedance be the reason for the obvious difference in frequency response and balance?
I've read up that using low capacitance interconnects are a must for passive preamps to prevent upper frequency early roll-off, the Little Bear seems totally agnostic to cables but I'm wondering if the Tisbury would benefit from lower capacitance.
I've made interconnects with Van-Damme XPE patch cable that claims 50 pF/f oot core to core but 95 pF/foot core to core? So wich is it?
I've splurged out on a pair of Mogami 2964 interconnects that spec 19.8 pF/f - wow!
Both the Van-Damme interconnects and Mogami are 300mm (1 foot in old money)
Strider
Nothing to see here
5,548
3,358
Mark
So if one were to use a Schiit Sys or Tisbury Passive Mk2 as a switch box between sources and a pre-amp would cable capacitance need to be considered?
I'd say so but of course my recommendation is to see if it works for you, I took a punt at the Mogami pair from Amazon because @ £23 I didn't think was to extravagant for an experiment..
Reactions: oldius
George 47
Subjectivist
9,580
6,823
United Kingdom
TWENTY THREE POUNDS of the realm!!!!!!!!!
You was robbed blind. If you had gone to the Newbury tip they sell used cables and you could have got a 2m pair of Nordost Odin Golds for a fiver. I did, just ask for Honest Arfur he'll see you right.
  • Haha
Reactions: Strider
Strider
Nothing to see here
5,548
3,358
Mark
:ROFLMAO: Noooooo!
Were you doing a bit of casual skip diving?
Arfur, Arfur sixpence and no more, Ahm cuttin' me froat alreddy San!
  • Haha
Reactions: greybeard
Mazerati
