Drive Belt Question
dj.gibby
Scottish Borders
Brian
Hi folks,
I have a drive belt to fit to my sisters Dual 505-3 record deck and I can remember reading a few years back that most 'flat' belts have a smooth side and one which is very slightly rough and sure enough it does but I can't remember if the smooth side or rough side is meant to contact with the motor pulley and platter. Can anyone shed some light on this or do you think that it won't make any difference?
Cheers
S
scruffybitch
dunno, but will guess the rough side in contact to improve friction.
Benolli
