Having recently built a MLTL test cabinet to explore the pro's and con's of this approach for a mid bass (30- 300Hz) enclosure, i was suprised by how room effects contributed to the FR response of the system. Due to the size and weigth of my test cabinet, i carried out measurements in my workshop, with the cabinet in the middle of the 8m x 4m floor. I initially used my usual approach to speaker measurement, placing the mic in the listening position, in this case the distance (2.5m) away from the speaker. The response did not replicate the simulation from MJK'S mathcad work book for MLTL's. Following advice (DIYaudio) i moved the mic closer to the speaker, carrying out near field measurements @ 300mm away the response and simulation are engineeringly similar. Using MJK's room placement predictor some of these room effects can be predicted, with the position of the driver and ports being significant contributors.
Having gone and confirmed that FR of my Onkens are also alot flatter when measured in the near field, in my listening room - I conclude the LF solution needs to be optimsed with the room.
This draws me to my question, ignoring the extreme effects i witnessed (15 db peaks and troughs) of my hard surfaced workshop, are all LF solutions as sensitive to room contribution? After the worst offenders have been precluded, how do i tune driver/port position, baffle size/shape etc to work with the room.
