Endowment policy matures; mortgage already paid!
awkwardbydesign
Perfect, apparently.
10,415
2,183
Alright then, a letter just landed on the mat; my endowment matures (unlike me) on the 1st of August. £17,863.38p paid into my bank. Imagine I could spend most of it on hifi, what should I do? Bear in mind I prefer to build or modify, not box swap. My room is about 5m x 4m, with lots of acoustic trapping done already.
I intend to keep my Oracle Delphi Mk1, but might upgrade the bearing and motor, and modify the chassis to Mk5 spec with a counterweight; I already have the Mk6 dashpots and Delrin feet and tower shafts.
Everything else COULD change, but not just for the sake of change.
Arm and cart at the mo are Decca International and Decca Supergold.
Phono stage is a Yaqin MS-12B, heavily modded. That should change, maybe get Coco to build an LCR?
Pre is a Promitheus standard TVC, that would certainly change, but maybe to a better version. Or a valve pre; Bottlehead maybe?
Active crossover is a 1981 Ben Duncan design, upgraded several times. If that goes then it's passive speakers.
HF amp is either a Ming Da MC84-C (EL84 PP) or funky little SET -http://www.ebay.co.uk/itm/121041038118?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
MF amps are Ming Da MC845-C monoblocks.
LF amp is a Parasound HCA-1205A 5 channel power amp; that definitely needs changing anyway as I no longer need more than 2 channels. I do wonder about the Parasound Halo power amps.
Speakers are a mix of EJ Jordan drivers and 10" SEAS bass units. I think I would prefer to make my own here, especially as I have just ordered a Behringer ECM8000 mic.
CD transport is an old Meridian 200 and the DAC is a Teradac Chameleon NOS. I like the look of the Oracle CDPs, but don't know too much about them.
I also have Qnap NAS + laptop, but prefer records and CDs.
Cables..... well we won't go there, eh?
I have no particular objection to Chinese or 2nd hand. 220v gear is OK, I have 2 variacs, or bucking transformers are dead easy to make up.
I would prefer not to have subwoofers, and I want fast open bass more than extra deep. Oh, and I quite like ribbons. Not to wear though.
Any chance of some sensible suggestions? :upgrade:
And don't worry about racks, etc; I'll make them.
awkwardbydesign
10,415
2,183
Shut up. It was bad enough taking YOURS to Scalford. And which part of "sensible suggestions" did you not understand?
Although these appeal. Could I get a matched pair?
awkwardbydesign
10,415
2,183
Nah, I intend to drink or drug myself to death pretty quickly.
BTW when I said sensible I meant in 'Wam terms, not normal people! :doh:
AmDismal
9,324
136
What a lovely problem :)
Stick with active, I suggest a Najda digital 4-way as the first thing to build. Dead easy - you add a PSU, box and buttons.
Sort the speakers first. A big J-horn could do down to 50Hz; lower than that would need something quite big - Lab sub style, or tapped horns. Then decide on what goes above; the J-horns would go up to 300Hz or so, so you could get a 160Hz horn (Stereolab?) above that, followed by S2s and a Raal ribbon - what a great 4-way system that would be. If you go for more bass, you need a mid-bass solution (build it big) for 100-500Hz, then some 2" compression drivers and Raals from 5k up, if you didn't want to go five way.
I currently use a big pro SS power amp for the bass, but I don't think it's needed - PP valve would be fine. Choose your amps based on the needs of the speakers, but generally SE would be fine except for the lowest stuff.
Sounds like fun :^
awkwardbydesign
10,415
2,183
Save the 38p and blow the rest on women and fast cars bikes :^
Fixt. I'm off to Pembrey tomorrow for a track day. Back on Monday. I hope! :nerves:
awkwardbydesign
10,415
2,183
:D
What a lovely problem :) Stick with active, I suggest a Najda digital 4-way as the first thing to build. Dead easy - you add a PSU, box and buttons.
Sounds like fun :^
Thanks for the first nearly sensible reply; however I'm allergic to digital processing (yes I know that's probably illogical, but hey, that's the kind of guy I am, even the DAC is NOS), and the room is only 5 x 4, not speedysteve's dedicated room (better curtains, too. :D ), and it will need space for people as well. Also, even if I CAN spend the money on hifi it will need at least a nod in the WAF direction. I managed to get the acoustic tailoring past SWMBO by hiding it behind fabric walls.
cjr
8,558
45
UK
Spend the whole shebang on the highest cost cables you can afford.
Jan 11, 2006
18,967
225
:D Thanks for the first nearly sensible reply; however I'm allergic to digital processing (yes I know that's probably illogical, but hey, that's the kind of guy I am, even the DAC is NOS), and the room is only 5 x 4, not speedysteve's dedicated room (better curtains, too. :D ), and it will need space for people as well. Also, even if I CAN spend the money on hifi it will need at least a nod in the WAF direction. I managed to get the acoustic tailoring past SWMBO by hiding it behind fabric walls.
Put a plant on top of the pretty big speakers should sort that problem. :^
awkwardbydesign
10,415
2,183
Oooh, sounds like fun! get that knee down!
That's me, that is. Knee down is no problem, getting it back up might be!
Haven't you got some work to do, or something?
awkwardbydesign
10,415
2,183
Now you're just being silly. I make my own. With batteries in them.
:nup: Bad back.
Lol, I had to think about that; I thought you meant me, as your post is just under that picture!
cjr
8,558
45
UK
Pah! you know and I do, that the most expensive cables you can afford will be much better.
crimsondonkey
2,927
107
Treat yourself to 17 nights with a £1000 per night hooker.
Use the £863.38 for sundry expenses and discretionary tips.
Boro53
