I'm running KDSM into poweramp and non-exakt speakers.
Assume I buy Exaktbox Sub and connect it to KDSM and use analogue output to non-Exakt active subwoofer.
I have come across two contradicting messages in Linn Docs on this arrangement.
The ExaktBox Sub Manual suggests that this is not goin to work:
You cannot mix the Exaktbox-Sub with the left/right speakers being fed from the Linn DS/DSM analogue sockets.
Konfig will allow you to set this up but no audio will fed to the ExaktBox-sub
But the FAQ Installation says that:
If you only have speakers connected via analogue connections to the Linn DS/DS
and try and also use the Exaktbox sub Config will only allow you to setup Space Optimisation+ on the Exaktbox Sub.
You will not be able to use Space Optimisation on the analogue outputs with an Exaktbox and or Exakt speaker connected.
which means that mixing is possible but I will be able to set up Space Optimization for Subwoofer only and not for the main speakers -- which is fine with me.
Can someone help to resolve this conundrum ?
