Firestone Audio 24/192 DAC
vacdac
11,536
280
Paul this looks like a good deal & I'm seriously interested....can't find a link to the Dac on Firestones site.....what are the inputs please on the Dac....I could do with something that is plug 'n play for usb or if not ideally two optical inputs. This is for my new Synology Nas in my bedroom system I do have a USB audio interface that is plug 'n play with it so I could still use that & still have the convenience of a proper on off swith for the Dac which my Lash up Fiio D3 24/192 doesn't have.
Any chance you can hold it for me until we have a chance to discuss this....as I don't mess around with buying stuff.
Cheers.
Chris W.
PM'd also
£110 including delivery UK mainland quick sale. As I don't have a box for the supplier.
vacdac
11,536
280
Just gleaned this from Firestones site >>
All products from Firestone Audio (except ILTW) are working with the Native drivers that are standard available in every Windows, Linux and Apple operating system. Just plug in the USB connector in you PC and it must be automatically recognized by your PC and work immediately.
Looks like this won't work for me & its I2S/USB only which isn't a good fit for me unfortunately. I also need summat that is plug 'n play for USB audio with pre installed audio drivers in linux as installing the necessary drivers involves buggering about with the Synologys CLI*(command line interface). The Cakewalk UA-1G does this just fine & is working brilliantly as a USB/SPdif converter so I may well stick with this for the time being.
ATB
Chris.
hifi addict
1,625
4
Hastings/ Crete
www.hifitraders.co.uk
Amplifier Structure : Low pass filter with 2Vrms output
Power Structure : High frequency switching DC-DC regulator
USB Support Format :
16 Bit : 44.1kHz / 48kHz / 88.2kHz / 96kHz / 176.4kHz / 192kHz
24 Bit : 44.1kHz / 48kHz / 88.2kHz / 96kHz / 176.4kHz / 192kHz
Digital Interface : Direct I2S data format transmission (MAX support up to 192kHz-24bit over 1 meter CAT-5E cable)
Operation Mode : Support Adaptive and Asynchronous mode for audio stream transmission
Circuit Protect : Output short / over current protect
DAC Chip : WOLFSON - WM8740
USB Chip : TENOR - TE8802
LPF OP : NS - LM4562
Audio Performance (1kHz sine wave, 2Vrms output, 24-bit / 48kHz) USB Input
dB-Weighed Frequency response (From 40Hz to 15kHz) : 40Hz +0.02dB, 15kHz -0.12dB
Total frequency response is of course much wider from < 20Hz till far over 20khz
Noise level (1kHz, A-Weighted) : -106.7dB
Dynamic range (1kHz, A-Weighted) : 106.7dB
THD% : 0.012%
Stereo crosstalk : -102.7dB
Housing dimensions : 117 x 80 x 50 mm (D x W x H). Housing only without parts 'sticking out' like connector parts, swithes, etc.
Weight : 286 gram (without the external power supply)
Boro53
