FIRST TIME ATTENDING
terryg1
640
109
Northampton
thought I would just see if anyone else is showing this year for there fist time ?  And also there thoughts on what music and equipment to use / bring 👍👍
Lawrence001
4,744
2,280
168
Lawrence
Easy, system wise the best sounding combination of components you've got, plus some more if you want to change things over the weekend.
Music, as much as you can, it's easier if you're file based, and if streaming then preferably HD quality (real HD not the Amazon definition [emoji38])
Reactions: terryg1 and Tony_J
Tony_J
20,686
Bunessan
Tony
Worth bearing in mind that unless you have made arrangements for a room sitter, you may not be able to escape your room from start to finish on the Sunday, so a stock of fluids (with or without alcohol) and something for lunch is always a good plan!
Reactions: terryg1
Ed Howarth
769
368
Isle of Mull
And remember that beds and cupboards will probably need to be moved. Don't struggle, just accost someone who doesn't seem to be doing anything (the bar is a good place to start) and ask for help. Seriously, everyone will be pleased to help.
And if you don't want to be bothered by someone asking for help, walk briskly around with a clipboard and a harassed look on your face :D
eddie-baby
6,459
3,219
Pembrokehsire
Eddie
I know I've heard long wave radio sound better than what Amazon put out, I hate it! The interface and lyrics thing is quite good, but SQ :nup: And unfortunately my daughter loves Amazon Music so Dad 'very' reluctantly pays for a subscription.
Tony_J
20,686
Bunessan
Tony
Fuses. Particularly if your kit uses internal fuses (as well as fused plugs), make sure you have some spares and the necessary kit (screwdriver, lump hammer...etc) to crack the boxes open to replace said fuses - they are often mounted in PCB sockets.
Reactions: terryg1
34,705
I'm in the middle of building power supplies. I've given RS's profits a bit of a boost in the fuse department today thanks to trying to rush things  :whistle:
34,705
My new phono power supply has quantum non-entaglement. I fix one issue and another appears in synchronisation. I'm reverting to Mk 1 for some listening and giving up for the night. At least the 845 is behaving itself now it's had some TLC.
Reactions: Tony_J
MF 1000
Extreme Full Range 😱
6,124
4,614
Caego
Keith
I would also advise against using Heisenberg fuses as you can never be certain if they are in your amp or elsewhere.
Similarly some say Einstein fuses are the best .....but I think it's all relative
......I'll get my coat  :rofl:
  • Haha
Reactions: Maverick and Tony_J
classicmetal
