First Tube Amp
AndyCC72
509
1,040
113
51
Bexley, Kent
Jazid, that’s an exceptionally generous offer. I’m that rare beast, a 51 year old man who doesn’t drive. I’d need to arrange a life from a friend.
I’ll drop you a PM once I’ve done so.
Thank you very much for the offer, very much appreciate it.
Reactions: Jazid
rdale
2,629
1,595
178
Gran Canaria, Spain
Richard Dale
I connect my REL T5x subs to my PrimaLuna Evo 100 via the REL high level connection, and it makes the integration with the main speakers perfect as it sounds like the system is driven by one giant valve amp. So if you are using the line level inputs of the subs now, it might be worth experimenting with the high level inputs with a valve amp.
newlash09
3,305
3,167
45
India
Y.Manohar / mike
If you fancy valve rolling (it's fun and sonically rewarding) and don't want to start messing with meters, probes and lethal voltages then I'd defo suggest an auto biasing amp.
It's actually quite important imo. I wouldn't buy another valve power amp without it.
I guess it depends. I usually check my manual bias once every 3 months. And on most occasions find that I don't need to adjust anything. But when I have to, it takes a good 15 mins per amp to get it all dialled in.
And since I have nothing else to do all day, I like hanging round my kit in the day. Tinkering where needed and setting it all up for the evening, when the music will start. I find the biasing part to be just as enjoyable as the physicality of handling my vinyl or my CD's.
AndyCC72
509
1,040
113
51
Bexley, Kent
Thanks, I’ll definitely do that.
I had the same 2 subs as you before I got the SVS’s and used to run them via the high level input into the Lyngdorf.
rdale
2,629
1,595
178
Gran Canaria, Spain
Richard Dale
That’s interesting, I’m really happy with my RELs - what made you change to the SVSs?
AndyCC72
509
1,040
113
51
Bexley, Kent
Two reasons, I wanted something that went a bit deeper and was more powerful. I listen to a lot of dance music and reggae; quite loud (my man cave is at the end of the garden so I can play as loud as I want) and just felt the small T5i’s, good as they were weren’t quite enough. The SVS gave me that bit extra I was after.
I also liked the fact they have the PEQ function. before I had my Lyngdorf 1120 with the Room Perfect DSP I struggled to integrate the subs. I thought If I ever move the 1120 on for an amp without room correction the PEQ will make integration easier.
Reactions: rdale
Dungtran
