FM Aerial installers in Warwickshire
gingermrkettle
1,541
35
Warwickshire
Stephen
I'm going to be moving up that way around the time the Proms start, and have permission for a bit of Ron Smith to go up on the roof when we do. Anyone know any good aerial installers around the area? Yes, I probably will ask them if they know any decent people as well when I get the aerial ordered.
FiftyPlus
518
11
, , United Kingdom
Try "Check A Trade" for quality of installation, but insist on directional yagi type of aerial pointed to the apropriate BBC transmitter. Three element will probably do unless you are in a bad signal area, but the circular "omni directional" type favoured by many installers is generally regarded to be a poor choice. I purchased my aerial on line and presented it to the installer to fit, as he was going to fit an omni directional one because it is the bog standard he fits on most blocks of flats (his main customer base).
hifinutt
16,566
4,862
midlands , , United
phil
asked my installer about them a few months back and he had heard of them . in the end I did the install myself because not enough room on the roof really so its on the garage [galaxie]
I am sure any competant installer will fit yours
