i have made an oak plinth for my garrard 401 but wondering about some kind of sound deadening between the plinth and the deck any thoughts [maybe some kind of sorbathane washer or gasket?]
a pic to ogle ati have made an oak plinth for my garrard 401 but wondering about some kind of sound deadening between the plinth and the deck any thoughts [maybe some kind of sorbathane washer or gasket?]![]()
this is before i danish oiled ita pic to ogle at![]()
No material will be rigid at all audio frequencies so the whole concept of rigid coupling between bearing and arm is flawed IMO.If you are fixing your arm and Garrard to the same top plate then introducing any compliant material between them effectively removes a fixed pivot to spindle distance. I stand ready to be corrected, but I don't know of any turntable manufacturer who does this???
Why?Agreed, the question then remains that at what point does a lack of rigidity have an audiable effect? I would still suggest that trying to introduce compliance between the motor unit and the arm to damp vibrations from a relatively low frequency input from the Garrard rumble machine would potentially result in an audiably worse solution.
Differential movement between the arm and motor unit. If I have fallen into a Pooh trap be gentle, I'm suffering this evening as it is. Mind you, never a bad idea to have accepted wisdom questioned.Why?
My view is that it's (differential movement) gonna happen anyway. Ultimately the cartridge is held in place via it's mass and cantilever compliance combination. vibration fed up the arm (perhaps by some nominally rigid coupling) from the motor unit is going to affect the cartridge anyway.Differential movement between the arm and motor unit. If I have fallen into a Pooh trap be gentle, I'm suffering this evening as it is. Mind you, never a bad idea to have accepted wisdom questioned.
It's not that it's not desirable, it's that I believe it's simply not possible. if you look at how what appear to be solid materials behave under dynamic conditions, I think you'd be surprised. I guess you can illustrate it by tapping a piece of metal (or whatever). If it makes a noise (any sort of noise) it's not rigid.It will go back to why you think it is flawed to have a rigid coupling, what would be the advantage of a compliant coupling, how compliant, in what axis?
I'm not suggesting so much compliance that speed stability is audibly compromised. In fact I'm not suggesting introducing any compliance, just pointing that the 'rigid' coupling (e.g. a steel or ally plank) isn't actually rigid at the frequencies of interest! Having said that, in the Garrard, isolating the arm mount from motor vibration would be a good thing, I'd have thought.If fully floating then surely the cart would just show pitch instability as it was first dragged up and then released back down the groove. I would assume that to be not desirable, so apply some damping and take toward the rigid end of the equation, at what point does it become desirable? Is it more than just a compromise between isolation of the arm base from motor unit or are you suggesting there is something inherently advantageous with a compliant coupling in it's own right?
Just my 2p FWIW (probably not much). I'm happy to be corrected.I seem to remember something from Origin Live that recommended not torquing the hell out of the fixing bolt on its tonearms as the more rigid coupling wasn't desirable, but it really didn't say much more than that. Cartridgeman has a compliant mount between cart and tonearm and Well Tempered are fairly unique in their approach.
You mean Pac67, who is now banned I think.
