Genexxa/Optimus LX5 pro users?
tackleberry
3,493
Leeds..
I’ve just purchased a pair, and just wondered what peoples thoughts were. I’ve seen a few pages on mods.
In particular the balance between the mid/bass and tweeter?
Also noticed a heightened upper bass. Any experiences?
bencat
Amplifier Destroyer
8,481
5,615
Andrew
Use three as my rear and centre speakers for my A/V set up Harbeth Compact Monitors do the front left and right . The tweeter is the best thing about it and stacking them shows great improvements heard four per side stacked at the Wam Show . I think they sound far better than their budget price and do reasonable bass if you put them on the end of a powerful amplifier It all KSA50 worked well for me .
tackleberry
3,493
Leeds..
Cheers bud, interesting that you use them for av.
I’ve had a better response from bunging the ports, though probably not a long term solution. I think I’ll change the cap and the ferrite, and see what the change is. I’ve tried to look at a few crossover designs but two of them won’t load, and the Dennis Murphy design isn’t visible to me☹️
rdale
2,439
1,333
178
Gran Canaria, Spain
Richard Dale
I didn’t change the crossover circuit, but I found the upper bass muddle is fixed if you upgrade the inductor to a air cored one, and the capacitor to a high quality polypropylene. I’ve documented what I’ve done in posts on this thread:
Post in thread 'Optimus / Genexxa LX5 crossover'
https://www.hifiwigwam.com/forum/threads/optimus-genexxa-lx5-crossover.51074/post-1886337
It Cost How Much!?!
Twisted
16,970
1,637
Hartford, Cheshire
Bob
A good friend uses them with a AE1 metal bass driver instead of the rather poor one that comes with the speakers, transforms them into something a lot better. The tweeter is just too good for the cab and bass driver.
p.s. if you take out the tweeters with too much power, I have a number of spares!
tackleberry
3,493
Leeds..
That’s good to know!
I’m going to have a little mess around with them in the coming weeks, going to try some new caps and coils, though the decent 6.2uf seem to be a little thin on the ground…
tackleberry
3,493
Leeds..
I’m sorted with both components, found some hovlands and coils from years ago! both measure 6.15-6.18 and reduced two coils from 2 to 1mH 👍 8EC1F525-E2EE-4FF9-BE1B-7D4B78CB2A7B.jpeg
Reactions: antonio66
dave
incurable tinkerer
1,484
794
cambs
dave
I personally find they sound best in a lot of cases, close to rear wall, maybe with some foam behind the tweeter. I blocked up the ports on mine and stuffed the boxes as full as I could. I changed the inductor to an air core in mine, and I think helped and the additional resistance probably helped the balance as well. I ran them with a sub. Very lovely.
tackleberry
3,493
Leeds..
Thanks bud.
I’m going to have a play around with wadding, I have some lambs wool to try.
I’ve got some air cores to yet connect. The main thing I found initially was the imbalance between the tweeter and the mid/bass. As well as the peak in the upper bass. I’ve started cleaning the tweeter components as they were quite dusty internally. Not sure how much of a difference this will make…
dave
incurable tinkerer
1,484
794
cambs
dave
tackleberry
3,493
Leeds..
Made a few changes. Few pieces of lead on the sides some lambs wool new cap+coil. The only difference I can see so far is the mid bass is slightly more capable at higher volume. Still have the over egged bass around 60-80hz CD1EF25E-9CBF-49F6-A3A7-3233AB2D129B.jpeg 57C73E29-F195-4876-B7E4-A43A92F7D561.jpeg
rdale
2,439
1,333
178
Gran Canaria, Spain
Richard Dale
You could try stuffing the ports with drinking straws.
tackleberry
3,493
Leeds..
Yeah I’ll try it when I get some.
I’ve just put them in my main listening room for a whirl. To be honest what they do do, they do pretty well. I’m just moving them back and forth to get the best of what they are on! image.jpg
tomasz1500100
