Goldenear Triton 7 - pre-orders
Audiologica
Audiologica
1,308
Horsham
Richard Santiago
The much-awaited Goldenear Triton 7 is almost with us, should get first stocks in less than one week
Pre-orders now being taken!01403 789 226
audiologica@btinternet.com
http://www.audiologica.co.uk/goldenear/goldenear_triton_7.html
We love Goldenear speakers at Audiologica - each model represents astonishing value compared to models from other brands costing far more! The Triton 7 is a truly remarkable compact floorstander that sounds far bigger than its price-tag suggests
The Seven’s unique cabinet shape is both acoustically purposeful as well as strikingly attractive. Its stylish rearward rake, in conjunction with the complex crossover, both aligns the driver array precisely for a coherent wave-launch directed at ear level at the listening position, as well as results in non-parallel front and rear baffles for better control of internal standing waves. And, of course, the non-parallel side cabinet walls and slanted top provide the same acoustical performance benefit, as well as looking great. The Seven’s precise and totally boxless imaging characteristics are further enhanced by the narrow front baffle, as well as the diffractionless designer grille cloth sock which adds additional sheer damping to the cabinet. In addition, the beautifully sculpted piano-gloss black base adds significantly to the Seven’s dynamic stability.
Like the signature Triton Two, the Seven combines a D’Appolito array of bass midrange drivers, which surround the same, now famous, High Velocity Folded Ribbon Driver (HVFR™), used in both the Triton Two and Three. The HVFR™ tweeter functions by pressurizing the air, rather than pushing and pulling it, for much better impedance matching with the air. This results in superb extension combined with a silky smooth non-fatiguing character, which is both unique and extraordinary. The spiderleg cast-basket 5.25” bass/midrange drivers, newly developed at our Arnprior, Canada engineering facility, have been specifically designed for exceptionally long-throw for tremendous dynamic range and extraordinarily deep bass response.
In addition, their precisely curved cone combined with a specially formulated polypropylene cone material and unique apical glue bonding technique delivers superb high-definition midrange clarity and presence. Like the two larger Tritons, the Seven incorporates 2 side-mounted sub-bass radiators that are located on either side of the cabinet down near the floor for optimum coupling to the room. The Triton Seven’s high-resolution sonic performance makes it perfect for the highest quality two channel systems as well as the best multi-channel music and home theater systems.
George steward
