Graham Phantom 2
Frenchsticx
5
Portsmouth
My Graham phantom tonearm has decided not to lower the arm onto the record, the cueing arm will go down with pressure but not on its own, anyone got any ideas about fixing it or replacement.
Thanks in advance.
DomT
9,647
8,301
Village near Nottingham.
Dom
If it is the silicon gel then be careful what you buy as I was once sold the wrong stuff by a UK dealer and had to buy from the USA.
Blzebub
Thundering bigot
2,183
1,414
Stamford, Lincs
Thanks in advance.
Contact the manufacturer. AIUI, Mr Graham is now very elderly, and the prospects for future serviceability are doubtful. This is why I didn't switch to one from my SME V.
Reactions: maddog_007
ACS
244
West Midlands
Scarlet Pimpernel
Where's my pencil...?
618
111
73
Totnes, South Devon,
Percy Blakeney
Just to be clear: is it the cueing arm itself that refuses to reach it's base position?
Or is that that the cueing arms drops okay, then the arm-wand slowly drops, yet doesn't reach the record surface...?
(I had a similar problem with my Graham Phantom II. But it was the headshell at the end of the arm-wand which has dislodged itself from it's unipivot base)
Reactions: Frenchsticx
Frenchsticx
5
Portsmouth
Hi I've just looked and it's the cueing mechanism, the arm is seated in the unipivot correctly.
markartist
