For Sale Graham Slee Revelation C MC Phono Stage w/ PSU1 power supply
For Sale
savvypaul
NVA Hi-Fi
HiFi Trade
Jan 11, 2017
6,117
7,677
Durham Uk
nvahifi.co.uk
£475 excluding delivery (£12 by RM Special Delivery, or you are welcome to collect). Located in Durham. Approx. 6 years old. Scooby the greyhound is not included!
Info from Graham Slee:
The following information describes both the Revelation M (Moving Magnet) and the Revelation C (Moving Coil). This listing is for the Revelation C with PSU1 Power Supply
Please check our other listings for the full Graham Slee range including the Revelation M
Revelation - Archival Phono Preamplifiers
Revelation Archival Phono Preamplifiers
Old & New Record EQ—Made Easy!
The Revelations will make it easy for you to archive older records.
As well as being a stereo RIAA preamp there are settings for other types of record, so rather than guessing the tonal balance, the Revelations have all the EQ settings you should need arranged on a three switch front-panel matrix..
There's a model for high output cartridges - the Revelation M; and a model for low output moving coil - the Revelation C.
The Revelation M is available with either the basic ("green energy") power supply or the PSU1 power supply for improved sonics. The Revelation C is supplied with the PSU1 power supply only. Both models are fitted as standard with a rear panel mono-switch.
Pre-set Equalisation for Repeatable Results
Our research into the equalisation required for numerous old record labels makes it easy for you to select the most suitable tonal balance time after time.
Being arranged as presets on front panel switches, the guesswork of variable controls is taken away, leading to repeatable results.
The different EQ settings will allow you to obtain a good tonal match to what the the original sound would have been on 78 rpm records, vinyl LPs and EPs
There is also an RIAA setting for modern stereo vinyl records, which makes it a significant stereo RIAA preamplifier.
The Revelations are suitable for professional archiving use as well as private use where you want the option to play and archive records from different eras.
Reactions: Non-Smoking Man
Non-Smoking Man
5,870
1,772
Chichester W. Sussx.
Jack lambert
Ideal for users with a sizeable mono collection as well as the usual stereo. I was on the lookout for one of these before the Tron Convergent single generator phono stage came up in the classifieds (which was an exact match for my Zero B mono cart).
Or for a user with an eye to getting a mono option going e.g., someone with an arm with a detachable headshell or provision or space for a second arm, e.g., Acoustic Signature, Solid, NA, 401 etc.
First example I've seen for 2 years since my search began. There are quite a few MC true mono carts to choose from - Lyra, AT etc.
The advantages of true mono and the quality of many mono records are things that are well documented now.
Jack NSM
Reactions: savvypaul
tomasz1500100
