Handling / cleaning valves
Jules_S
Are we there yet?
3,336
Southampton
Jules
Quick question - when handling valves do you have to be careful with the grease from fingerprints, in the same way as you would with, say, halogen car headlight bulbs? I'm unsure if any surface contaminants on the glass could affect their life or reliability. I'm sure you "old hands" with tube amps will be laughing hysterically at me by now!
I am eagerly awaiting the arrival of my new amps, which hopefully will be later on today. I am looking forward to a good cleaning session once they get here!
Ian
5,406
3,478
United Kingdom
Ian
No laughing here, if you're unsure, ask the question 🙂. But no, they're not like halogen bulbs and bare fingers are fine.
So, come on then, what are you getting ???
Reactions: rabski and Jules_S
Ady
Shoebox Ady. United by a love of music & equipment
659
1,370
Oadby Leicester
Adrian
As above, and also when removing a valve from its socket try not to pull out by the glass use the base if possible.
Cheers Ady
pmcuk
6,722
Kensington, London
Don't clean the glass or you will rub off the markings and so devalue the valve. Even water can rub off some markings. The other problem is a valve with no markings can be hard to identify.
Reactions: rabski and Ian
Ian
5,406
3,478
United Kingdom
Ian
And your manual probably says this, but it's wise to leave valves to warm up for a minute or so before playing. Sorry if this is patronising !
Reactions: Jules_S
Benolli
