HELP! With a Beomaster 5000, no sound & smoke!
taff
653
4
South Wales & Lo
Afternoon chaps!
I've been given a Beomaster 5000, which powered up fine, all lights came on etc ok.
However, no sound came out of it! When you plug in a speaker there is a crackle from the speaker, then nothing.
After trying a few things and having it powered on for a bit, I noticed a small wisp of smoke coming out of it near the input tray.
So, I thought what the hell and opened it up.. after a bit more plugging in and dismantling I narrowed the smoke down to R38 and r39 burning away merrily. I've had a quick trawl and can only find that this is common ish, but the problem is possibly deeper than the resistors. They are on the pre-amp side as i under stand it!
Looking for any help you may be able to give! Layout diagrams, experience of this unit etc! Not sure what to do.. I have limited soldering expertise/ experience but am keen to learn and see this as an opportunity to do so. Am I mad or shall I just stick it on eBay? Is it worth fixing?
EDIT. At least I've found a copy of the manual with the resistor values. Tempted to replace them with wire to see if that works.. is this a bad idea?!
http://beophile.com/wp-content/plugins/download-monitor/download.php?id=145
Cheers!
James.
killie99
2,218
427
Kilmarnock
Stuart
you need one of these and one of these. They're a good alternative to the bits of wire you're planning to replace the resistors with but will get you the same result a lot quicker. :^
Radioham
1,911
344
163
Peterborough.
Alan Ralph
Can you post a photo of the area,or name some of the other parts nearby,since if you look at the circuit, the same resistor numbers are used on different boards. So if there is a nearby integrated circuit, eg ic? Would help a lot. Using a wire link is a bad idea , unless you want it destroyed.
Who Cares?
383
10
23
Afternoon chaps! I've been given a Beomaster 5000, which powered up fine, all lights came on etc ok.
Cheers!
James.
Erm, your link requires a subscription.
Anyways, I would assume the manual will provide a testing process, needing test equipment to confirm values at certain points.
Now, if you are totally confident in your knowledge of ss circuitry you could attempt a repair without the requisite test equipment.
That said, if this item is of little worth to you and you want to learn, initially just replace those resistors. Then, if that doesn't get it working you'll have to come to a deeper understanding of how this stuff works.
It's a good thing to know more.
