I’ve used them in the past and also found them to be excellentI've bought a couple of bits from Analogue Seduction in the past. Absolutely no issues, and on one occasion 'above and beyond'.
No idea where they get the original £120 from. The cable can be bought for £20/m add at most a fiver for plugs shown. The cable is nothing fancy just standard 3 core flex except it is twisted.Not commenting on whether they are worth bothering with or not, but these Black Rhodium mains cables are heavily reduced. Other lengths also available:
https://www.mcru.co.uk/product/blac...power-cable-clearance-1-7-mtr/?v=79cba1185463
Don't disagree, but not everyone has the means or capability, and there is the cost of the connectors at both ends to factor in, which are probably more than a fiver's worth. So to get it made for you professionally (and remove some doubt that you've done it badly) for a little more than the cost of the parts seems a decent deal to me. Realise it's not for everyone, though, especially those that can DIY.No idea where they get the original £120 from. The cable can be bought for £20/m add at most a fiver for plugs shown. The cable is nothing fancy just standard 3 core flex except it is twisted.
So why not twist your own and have a real bargain.
The £55 is much more realistic it was the £120 I took exception to. Any you can certainly get bothDon't disagree, but not everyone has the means or capability, and there is the cost of the connectors at both ends to factor in, which are probably more than a fiver's worth. So to get it made for you professionally (and remove some doubt that you've done it badly) for a little more than the cost of the parts seems a decent deal to me. Realise it's not for everyone, though, especially those that can DIY.
I certainly wouldn't be paying £100+ for any power lead!The £55 is much more realistic it was the £120 I took exception to. Any you can certainly get both
plugs for under a fiver.
I don't either , May have 50 or 60 year old wiring in the house then put a massive cable into the plug socket 🤔I certainly wouldn't be paying £100+ for any power lead!
