How many switched inputs on your preamp do you use?
pmcuk
3,080
Kensington, London
Can you help all us DIY preamp builders by telling us how many pairs of RCA single ended inputs you use on your preamp? And what they are?
1 pair (L+R)
2 pairs
3 pairs
4 or more pairs
This is just line inputs for a line only preamp.
Doesn't apply to phono stages which would not be in a line only preamp. An input from a separate phono stage would count, however.
Doesn't apply to balanced inputs either via XLR, just RCA inputs.
MVJ
I'm an Entheogenic Type Ozric Tentacles Shpongler
12,517
24,435
198
Guiseley, Leeds,
Steve,
I use three pairs for all my inputs which are, Phonostage, Streamer, and SACD player.
Output is XLR to Event Opal Speakers.
Batty
922
298
Adelaide. Oztrayliya
Steve
3 pairs.
1. Output from DAC which has 5 digi inputs. USB from laptop, opt from SB touch, coax from CDP.
2. output from MC phono stage.
3. output from MM phono stage.
MF 1000
Extreme Full Range 😱
6,123
4,611
Caego
Keith
There are only two pairs on my DHT pre…I use one for cd one for i out from my sky box or Bluetooth adapter
34,628
Five. I don't normally need that many, but for my own builds I may as well have too many rather than too few. Normally I've got two phono stages and the DAC plumbed in, but it means I can run an input direct from the CD player and still have a spare input for testing and comparing things.
Sotosound
707
508
98
Buckinghamshire
Ian
Four, but will probably end up using the fifth as well.
Phono
CD
Streamer/server
TV
Cassette
I had the fifth added through a customization prior to purchase.
Tony T
Tony T
120
122
63
Tony
3 pair RCA inputs use 1 for Phono Stage
2 pair XLR inputs use 1 for DAC
4 pair XLR outputs use 2 for Antimode 2.0 and monoblocs.
All balanced.
Alvolake
629
50
58
Canaries, , Spain
Just 1 which really means none as it a default setting. That way I used the input switch knob to control the volume of another pot thereby improvising a balance control on my A21SE.
uzzy
Grumpy Old Git
8,239
4,100
NN38TA Northampton
my SP9 provides me with just enough RCA inputs 6
Phono (for you line stage with phono pre in front)
Tape 1 (I have a cd recorder plugged into this and the output from tape 1 into the cd recorder)
Tape 2 (I have the DACplugged in here and this is handy for comparing DACs against the CD or streamer built in one)
CD
Tuner/streamer
Video (tv input)
Also vital the number of outputs
Tape 1 output (into the cd recorder)
Tape 2 output (my headphone amp is hooked up here)
Main pre output
(You might like to double up the Main Output to allow for Biamping (not that I would bother)
pmcuk
3,080
Kensington, London
This is very helpful!
- many more need 3 input pairs than 2 inputs, so that should be designed in
- not sure what to do about 5 inputs. Maybe leave space to fit if needed.
Keep the answers coming! Very interesting!
34,628
It's a pain to build though.
Enough casework room for five pairs of inputs and (at least) one pair of outputs. Plus the hideously time-consuming wiring to the selector switch. My original kondon't clone was six inputs and I switched ground and signal. That's 24 wires from sockets to selector switch. On the bright side, at least I didn't try and do it with Litz stuff...
Reactions: pmcuk
hifi-junkie
