Linn Owners
How properly clean Ekstatik stylus?
kryno
Nicolav
163
255
Nicola
I was wondering how best to clean the Ekstatik stylus.
For the kandid Linn recommended the green paper, the vibrating pad or the liquid of Lyra.
Will these systems work for the Ekstatik as well? To put it better, are they equally safe on this cartridge?
What do you use?
Reactions: Moomintroll
sktn77a
Audio Dinosaur
1,137
1,054
NC, USA
Keith
You're going to get multiple opinions on this. I was never a fan of the "green paper". Sure it's Linn's recommendation but I don't think Lyra (the manufacturer) would go along with it (if they weren't gagged by Linn).
Reactions: Daveyf
kryno
Nicolav
163
255
Nicola
I think you’re talking about the Kandid, but what to use for cleaning the Ekstatik?
HBerg
187
136
Any of these little carbon brush jobs.
Forget anything wet as capillary action can ruin the coils.
I use one of those on my Benz Micro LP. I have the green paper but would not use it on an expensive cartridge.
Reactions: Mr Kandid
Ron.P
276
428
The Lyra SPT liquid is good for all cartridges.
Agree. Just use common sense: Do not soak the brush; just a drop is needed. Then brush the stylus, not the cantilever.
Peter Lederman told me to use Blue Tak. But when I dropped the stylus onto the Blue Tak, gooey material stuck to the stylus and came up in a scary string. Yikes!
I use the Lyra SPT once per month and my stylus told me in a kandid conversation, that it's quite pleased.
Reactions: Daveyf
airV
50
23
What is wrong with "Green Paper"?
I used Lyra SPT liquid 2 or 3 times when I had Lyra cartridges. But I don't really like wet cleaning.
Reactions: ThomasOK
HBerg
187
136
An expensive cartridge like mine has an expected lifetime of appr. 1400 hours on a relatively soft material as vinyl is. I don't like the idea of brushing it with a hard material as the green paper is. Of course the time you brush the stylus is limited but anyhow, I don't like the idea.
airV
50
23
I use the "Green paper" on my Miyajima Madake cartridge which is rather expensive, without any problem.
I use the "Green paper" about every 4 or 5 records, and a small carbon brush like the one shown by Mr Kandid before playing each side
Whether it's with the "Green paper" or the small carbon brush, I only brush the stylus when the arm is free and not blocked on its support.
  • Wow
36,207
Wire brush and dettol.
Alternatively, if you want it to last, I've always used one of the gel pad cleaners. As long as your vinyl is sensibly clean to start with (essential), then it should only be fluff, hair and dust that gets on a stylus.
I know that AT are happy to recommend a wet clean solution, but I'm extremely wary of any fluids when there are flexible parts that could be affected.
Reactions: Mr Kandid and airV
Moomintroll
3,417
4,305
Whilst vinyl is softer than the stylus, for each LP side the stylus travels about 450m compared to a few mm for each swipe of the green stuff. A stylus is much more likely to wear out from playing than from cleaning. IMHO.
‘troll
airV
50
23
If the discs are washed with a product like "Art du Son" without rinsing, there are residues of the product in addition to fluf, hair and dust.
Reactions: kryno
airV
50
23
‘troll
I think it is more the cantilever that is likely to be damaged during cleaning than the stylus itself.
That's why I prefer to brush with the arm free rather than locked to the holder.
The green stuff is soft enough not to damage the cantilever.
36,207
Which is why I would never use any cleaning solution other than in a vacuum machine and with sufficient surfactant in the mixture.
I'm reasonably fussy about a lot of things, but I'm a real diva when it comes to having clean vinyl :ROFLMAO:
Ron.P
276
428
I still use my VPI vacuum machine for pre-cleaning really filthy vinyl. But I mostly use my Degritter ultrasonic which is a brilliant device.
airV
50
23
I use a vacuum machine, a Loricraft PRC4 and I always rinse after washing with a product like Art du Son.
I must try the Winyl product. I hear that rinsing is not necessary.
airV
50
23
I don't really like ultrasonic machines. My experiences with a Klaudio were not very successful.
I prefer a good vacuum machine like Loricraft or Keith Monk
Boro53
