I have two pairs of hi fidelity RCA's, and one coaxial digital spdif cable. They all look exactly the same 😜😜. And I mixed them all up. Any way I can find out which one is the digital cable. I do have a multimeter at hand. Thanks in advance 🙏
This.The characteristic impedance of an S/PDIF cable needs to be in the order of 75R. You cannot reasonably measure this, unless you have an infinite length to work with.
Fortunately the impedance of any normal piece of coax will be about right.
So it's extremely unlikely to matter which cable you use for digital, even if they're somewaht different.
But to be paranoid I would take a look inside the plugs and see if you can spot the odd one out.
