I bet the cables the OP currently has already do all that is needed.Don’t forget to factor in some reasonably made cables.
With a modest £1200 budget, you should ditch the idea of vinyly playback equipment. That alone will easily swallow your entire budget and if you allocate a %age to TT arm and cartridge, the SQ will be worse than streaming.Components needed: turntable, amp (with phono stage and headphone out), speakers and closed back headphones
Have you possibly not read the full thread? Vinyl is not going to be dropped.With a modest £1200 budget, you should ditch the idea of vinyly playback equipment. That alone will easily swallow your entire budget and if you allocate a %age to TT arm and cartridge, the SQ will be worse than streaming.
If vinyl is left for another day (or dropped), then your budget will allow for an all-in-one, or all-in-two solution that will provide streaming, radio, payback of ripped CDs, etc plus a half decent pair of speakers - best bought used as your money will go twice as far.
Bluesound or NAD are iobvious brands to look at - NAD if your budget can stretch as they are better and more features (perhaps a phono stage for the future) and both brands offer the excellent BluOS control app, so no Roon to consider.
Do you know what they are?I bet the cables the OP currently has already do all that is needed.
No but if they work they'll be fine IMHO, particularly with this sort of budget.Do you know what they are?
Absolutely, and no need to go down the "X% of the budget should be for cables" rat-hole. Cables that work well need not be expensive.No but if they work they'll be fine IMHO, particularly with this sort of budget.
Thanks, that's the opinion I was hoping for on cables, having seen interconnects sell on here for more than my total system budgetAbsolutely, and no need to go down the "X% of the budget should be for cables" rat-hole. Cables that work well need not be expensive.
Great starting point.He's better off with these while they're in stock. I'd buy them myself if I was after a pair of new speakers in this price range. Free delivery too.
[URL]https://www.sevenoakssoundandv...ustics-concept-40-floorstanding-speakers.aspx[/URL]
Great price tooGreat starting point.
https://www.beoworld.org/prod_details.asp?pid=957B&O Beosystem 5000 - £600
B&O Beovox S80 speakers and stands - £300
B&O H6 headphones - £200
Beer, oreos and cake - £100
Sorted.
Yes, I read it - hence the cautious and carefel wording of my repy. ;-)Have you possibly not read the full thread?
Thanks. In the background I was thinking about spending a big chunk of my budget on an amp and, knowing the value of what I had already, I was interested in whether I'd end up with a 'balanced' system (if that's a thing!).Knowing the speakers you currently have presents a significantly different question than starting from scratch does.
So, unless I’ve misunderstood, you’ve really got £1200 to spend on (a probably secondhand) amp to power your Neats, and buy a turntable/cartridge, yes? Unless you were supposing you’d px your speakers?
I'm not sure this has really been covered above. Rather people have suggested your speakers aren't likely your current weakest link and that cheap speakers are likely to be worse than you already have.most people prioritise amp over speakers.
I don't think that is the case at all, maybe you misunderstood.What this has taught me is that my TT/Cart needs attention and most people prioritise amp over speakers. I was thinking the opposite.
Typo, corrected!!I don't think that is the case at all, maybe you misunderstood.
You have quite expensive speakers already.
