Wondering if anyone has retro fitted an SSD drive to an Innuos machine and if they experienced any issues. Thanks
1) Yes I have. 2) No I didn’t.1) Wondering if anyone has retro fitted an SSD drive to an Innuos machine 2) and if they experienced any issues. Thanks
What model INNUOUS did you do the SSD swap out on? Just curious what the differences are between their old Vortex based ones and the new 2.0 OS models.1) Yes I have. 2) No I didn’t.
but you need to know how to and have the skill or have available the correct disk cloning software (I only found one that can do everything required in the correct way) to create a multi partition disk with FAT32, EXT4 and Linux formatting in the different partitions and to be able to resize the final EXT4 partition at the end of that process. I would not want to encourage you if you do not have the skills so I am wary of posting a DIY set of instructions.
It was a Zen Mk3 with a spinning 1TB HDD. I replaced it with a 4TB SSD. When I did it the Zen was running the old pre 2.0 software and then when 2.0 was released it just updated to that as per normal. I have done it also on a Zen Mini and changed its HDD to a SSD which is now owned by @DomT and I assume is still running without trouble. Just clarify I have only ever done this on my own devices by way being a bit of tinkering. I don’t intend to get into doing this!What model INNUOUS did you do the SSD swap out on? Just curious what the differences are between their old Vortex based ones and the new 2.0 OS models.
Thanks, just curious, it was being discussed on another forum as to whether it was possible or needed RTB, I work in IT so was wondering what they might have done to lock it down like an EPOS or KIOSK PC to stop a bit of DIY Cloning/Gparted action onto a new disk.It was a Zen Mk3 with a spinning 1TB HDD. I replaced it with a 4TB SSD. When I did it the Zen was running the old pre 2.0 software and then when 2.0 was released it just updated to that as per normal. I have done it also on a Zen Mini and changed its HDD to a SSD which is now owned by @DomT and I assume is still running without trouble. Just clarify I have only ever done this on my own devices by way being a bit of tinkering. I don’t intend to get into doing this!
Putting the cd in my transport seems far easier1) Yes I have. 2) No I didn’t.
Running very well thanks and no issues at all. In fact I am so taken with the sound of the Innuos and the amazing user experience with their new app that I have bought 40 CDs to rip to the hard drive and haven’t really done any streaming.It was a Zen Mk3 with a spinning 1TB HDD. I replaced it with a 4TB SSD. When I did it the Zen was running the old pre 2.0 software and then when 2.0 was released it just updated to that as per normal. I have done it also on a Zen Mini and changed its HDD to a SSD which is now owned by @DomT and I assume is still running without trouble. Just clarify I have only ever done this on my own devices by way being a bit of tinkering. I don’t intend to get into doing this!
Well if you mean moving to where your CDs are stored and searching for the title that you want, opening the case, taking the CD out, opening the CD drawer mechanism, placing the CD correctly in the drive, closing the drive and then pressing play, then yes this is far more work than listening to ripped CDs. The ripping can take some time but once done you will save a lot more time afterwards.Putting the cd in my transport seems far easier![]()
