A little backstory:
I’ve been having tracking issues with my Funk Vector Anni-modded Pink Triangle Export rig for years now, gradually swapping components out to try and pin down the problem… Recently came to the grudging conclusion that it’s probably the deck itself (geometry issues with the armboard mount?), so decided to try something completely different – so I bought the zebrano Inspire Monarch that Purite Audio was advertising in the Trade Sales forum.
The Monarch is Inspire’s take on the ultimate direct drive deck. It uses the drive chain out of the venerable Technics 1200 series, and swaps out pretty much everything else for higher-quality parts (bearing, electrics, PSU, platter) and sticks them in a solid aluminium plinth sandwiched between two great slabs of beautifully-veneered plywood. Rock-solid, massive, immobile, driven by a by a beefy direct-coupled motor, with plug-‘n-play push-button usability – in every way the opposite of the Pink Triangle, which is a lightweight, delicate, belt-driven, wibbly, suspended deck (lots of acrylic, carbon fiber, balsa wood)!
Last night I fitted my newly-serviced Hadcock 242SE arm, and beloved Music Maker III cart, and gave it a whirl. Setup was super-easy – plonk it down, install the arm, press “go”, instant 33.3rpm. Hooray! Blessed relief after years with the fiddly, delicate Pink.
So I’ve only had one evening to listen to it so far, and I’m not sure I’ve found the Nth degree of perfection in the settings – VTA, VTF, antiskate, etc. Also, the support it’s on isn’t quite ideal – top MDF shelf of a basic Target welded rack. (Need to investigate isolation platforms…) So this is just my first impression, based on 3-4 hours of listening, and a handful of record sides. Also, it’s been a while since I had a good long listen to the Pink, so comparisons are vague and mostly from long-term memory (unreliable!)
So, how did it sound? Some things were unsurprising: it’s rock-solid, with impeccable timing and pitch, and super-stable soundstage. Bass is big, deep, powerful, and punchy. Frequency response is even, neutral, and very well-extended at the extremes. Resolution is very high – lots of detail, especially endless inner detail.
But some things took me by surprise: it has incredible 3D depth, with the soundstage seemingly extending far past the plane of the speakers into the wall and beyond. It has a refreshing clear-eyed presentation that feels very honest, neutral, and a little up-front/lightweight. It is sweet, liquid, and completely free of grain. It has tonal colour to die for – incredible technicolour stuff, just beautiful. The best I think I’ve heard from any source component. Voices and instruments, even massed in an orchestra, sound so rich and varied and beautiful… wonderful. And lastly, it has a liquidity and expressiveness, and a taught dynamic tension, that are just spellbinding. Voices, breaths, instruments (especially strings) ebb and flow with the music...
Some highlights from my listening sesh:
- Bjork’s “Post” was a LOT of fun! That thar’s some BIG, deep, tight, slammy bass, with great velvety texture – yumm!
- Jeff Buckley’s “Grace” was mesmerizing… The “audiophile” staple Hallelujah was unsurprisingly stunning, but the dense, rockier tracks were also very well served, with difficult rhythms and swings picked out engagingly. Noticed the wonderful guitar riff in the song Grace for the first time – it had amazing texture and colour, and great groove.
- Elvis “Elvis Is Back!” was wonderful. Up-tempo songs were fun and boppy, down-tempo songs had some incredible vocals. Elvis had really rich tones, soulful, and full of body and texture.
- “Bags’ Groove” - Milt Jackson’s vibraphone sounds increhooodible! So crystalline, present and real.
So… that was a tad gushy (understatement!), but it wasn’t all good. This clear-eyed, up-front presentation has pros, but it’s also a bit unforgiving, and a bit “hifi”. Listening to it, you feel like you’re listening to a very clear window on the recording, rather than feeling like there’s musicians in your living room (which is what the Pink Triangle does). It’s a bit brutally honest, and a bit lacking in warmth and fullness. It’s even a little matter-of-fact – it doesn’t leap out and you and bloom into the room like some (and like the PT does to an extent). It’s not the kind of sound where you can forget about the audio reproduction chain and just enjoy the music, like I want to. Also, with my ATC actives, I think there’s a little too much of that lean/neutral/honest/unforgiving character – so for me, system synergy isn’t ideal.
It’s very early days yet, so I’ll do some more heavy listening before coming to any conclusions. There’s a few things I want to try too. I need to experiment with VTA and VTF to be sure everything is at its best. I want to try my Funk Achromat on the Monarch – it’s not supposed to benefit from mats, but I’m curious nonetheless. Wonder if it might skew things slightly towards the PT’s more open, forgiving character… I’ve also got a slightly knackered (but still functional) Dynavector 17D3 lying around that I want to try on it in lieu of the Music Maker. Maybe its character will gel better with the Monarch’s in my system? If nothing else, I’m curious.
Will update when I have more to report…
Cheers,
Dunc
P.S. – The bleeding tracking issue was still there! Means the PT deck is presumably OK, but the cart must be at fault… Will probably just stump up for a brand new Music Maker – had my fill of second-hand carts…
Cheers,
Dunc
