Integrated amps with a passive pre section ... A question
lordmortlock
Lordmortlock
3,075
231
I've read a few articles/posts over the years in which users/reviewers add a separate active pre amp to an integrated with a passive pre section. Most have these have related to ART or EAR amps. My Almarro a318b is designed in this way and I'd like to try a valve pre up front for experiments sake.
By fully opening the passive pot are you completely defeating it? I suppose that's probably design dependent. My AN Dac output 2.0v so no issues driving the passive stage, this is more a play about to see what a high quality pre adds. Anyone tried this with the Almarro by chance?
anubisgrau
3,800
28
Belgrade Serbia
Gordan
By fully opening the passive pot are you completely defeating it? I suppose that's probably design dependent?
yes, it's a design dependant but most of the attenuators in zero attenuation position (wide open) are basically a piece of wire. it doesn't necessarily mean it's 100% transparent but at least it shouldn't interfere with the source impedance which is a main mess there.
basically it's a source pass position and the best when attaching an extrenal active preamp (because of its fixed impedance where no level of attenuation would affect it).
lordmortlock
Lordmortlock
3,075
231
Good, thanks Gordan. I like this set up well enough already but would love to hear what an AN pre or similar might add.
meninblack
24,223
1,358
Don't be frightened to experiment and see what sounds best. I use my amps with the input attenuators on the Air Tight set at about half way, so the normal listening range on the AN volume controls is around 9 - 12 o'clock.
AN pres have high gain, so having your passive volume control wide open can leave you with very little volume adjustment!
Lefty
2,884
385
In your town
Go for it Jake - this is exactly what I am doing with my Puresound A30. (Which has a passive pre section).
I am using a Conrad Johnson PV10al to good effect. (and a pair of Rothwell attenuators to compensate for the high gain of the CJ pre)
Lefty
bugsaint
