In your system which cable do you consider to be more important - your interconnect or speaker cable ?
Exactly! What's the point?
Why do you ask?In your system which cable do you consider to be more important - your interconnect or speaker cable ?
If you have a all in one integrated then you don’t need interconnects so that would make speakercable more important.Nothing works without both so both are just as important as each other![]()
But if you have active speakers, then interconnects are more importantIf you have a all in one integrated then you don’t need interconnects so that would make speakercable more important.
Tru datIf you have a all in one integrated then you don’t need interconnects so that would make speakercable more important.
My wife says the speaker cable. The colour must absolutely match that of the carpet!In your system which cable do you consider to be more important - your interconnect or speaker cable ?
You are an architect and you have carpet rather than wooden floor boards? Tut tut! (Sorry)My wife says the speaker cable. The colour must absolutely match that of the carpet!
Carpet must be laid on something also carpet is better than bare wooden floor boards as it improves acoustical responseYou are an architect and you have carpet rather than wooden floor boards? Tut tut! (Sorry)![]()
