That website is a little confusing, and also not always technically accurate. Basically, any interconnect, no matter what it's connecting together, has the simple function of transferring an electrical signal. Any interconnect has electrical properties of inductance, capacitance and resistance. Ignoring the relevant formulae (I did say 'basically'...), these electrical properties would ideally be as near to zero as possible, to stop them having an effect. However, see below.
These properties will be more important for connecting between a cartridge and phono stage, but they are important in any connection. With a cartridge, moving magnet designs are affected by capacitance and need capacitive 'loading' to even out the frequency response. Moving coil cartridges are similarly affected by resistance. Capacitance in such cables is thus important, but provided it is low enough, all that matters is that you need to know how much it is. Most MM cartridges 'want' a capacitive load of about 100-200pF. Although a phono stage will have an inbuilt loading, it is often lower than this, so the total capacitance of the cable(s) between the cartridge and phono stage can actually be an advantage if is it more than zero (and it will always be more than zero).
The comment 'made for impedances....' is sort of incorrect. Every source and everything a source is connected to has an impedance, but within reason, a cable will have little effect on this, unless it has one or other property that is much greater than ideal.
The 'resistance' is a red herring. Most MC cartridges need a resistive load of around 100 ohms. No cable will have anything like that, by a factor of a million or so. For all intents and purposes, you can ignore cable resistance in this regard (though it should be extremely small no matter what). Unless a cable has been deliberately engineered to have resistive properties (it shouldn't), you can forget about it. It won't have any effect.
Lastly, the most important factor is the one that website actually fails to mention: screening. The lower the level of the signal, the greater the possible effect of picking up electrical interference. Therefore, with a cable used to connect a turntable/cartridge, decent screening is crucial, for the connection between a preamplifier and power amplifier, or a CD player and amplifier, it is far, far less important and may not even be necessary at all.
TLDR? Assuming it's properly made and decent enough quality, any cable with an RCA plug at each end will be absolutely fine.
