Yes. No. Maybe.Hi I will have a 55 inch TV between two speakers which are 8 feet apart, any idea if LED screen is as reflective as a Plasma glass screen? I want to choose the less reflective screen. Yes this is a 2 channel, not a TV, debate.
De nada pal. No disrespect, etc. I presumed sound reflection, but TBH if you're in the market for a 55" TV, then keep the bloody hi-fi separate anyway.If the OP is talking about sound reflection then my bad - apologies. It was rather unclear from the original post though. I couldn't comment on how reflective sound-wise a TV might or might not be so the advice to go for plasma at that size stands.
Ha! Ha!I think the OP should take time to reflect on the clarity of their question.
This is exactly what I did. Made a light wood frame which fits on the screen, filled it with rockwool, stapled some nice fabric front & back. Job done. Since it exactly fits the screen - which is buried in the wall - when you're listening you forget it's there. I think flat screens have become some sort of status symbol. Bury it in the wall & cover that thing when not in use !Suggestion re screen reflectiveness. For music listening you could have a fabric cover made. Obviously not for AV use though !
Very good ! My friend Rick O'Shea enjoyed that pun (I'll get my coat......).I think the OP should take time to reflect on the clarity of their question.
