Thanks for the compliments. And I shall be very interested to hear your findings on using the Nobs under a TT. I have been wondering about adding some isolation under my own TT - it's on a wall bracket but due to the proximity to the RH speaker, the shelf does pick up airborne vibration and, it seems, transmit it to the deck's plinth / top plate. That said not much, if any, seems to get through the suspension to the subchassis, nevertheless I would hope to reduce it a bit, accepting that there will still be some direct airborne vibration.Impressive little build. And those Nobsound springs give me an idea for my turntable... Will investigate and report accordingly if They will go where I think they will.
Note my earlier comment about these, however. They do make some mechanical noise, as the springs rub against their locating holes when they move. I tried them under my turntable and they were no good. You could actually hear the rubbing amplified through the system. Some thin PTFE sleeving or similar might work, but I couldn't be bothered...Impressive little build. And those Nobsound springs give me an idea for my turntable... Will investigate and report accordingly if They will go where I think they will.
Interesting - thank you for reiterating as I had missed that. For the price there are probably better things I can try first in that case as I agree faffing around with sleeving etc given the initial cost. Will see...Note my earlier comment about these, however. They do make some mechanical noise, as the springs rub against their locating holes when they move. I tried them under my turntable and they were no good. You could actually hear the rubbing amplified through the system. Some thin PTFE sleeving or similar might work, but I couldn't be bothered...
I've used them under my tube amps with great results. I needed a total spring weight of 28 kgs ( 1.65 kgs per spring = total 18 springs ). So I adjusted the entire distribution of springs, such that I had more springs at the back ( to support the transformer ), and less springs at the front. I did have to experiment with the spring distribution a few times, till I got the amp perfectly horizontal. Once done, there was a definite improvement in clarity and imaging to my ears. I was previously using the 'oehlbach XL Air springs" under the amps, which had improved over the stock footers. And the noob sound springs when properly placed and balanced to get the optimum compression of 3mm between the upper and lower springs, improved it even furtherHas anyone tried the Nobsound springs below amplifiers?
Thanks for the post. I might acquire the Nobsound springs to try under my solid state amps and preamp. It's useful to note that the optimum compression of the spring is 3mm measured between the top and bottom aluminium alloy pieces.I've used them under my tube amps with great results. I needed a total spring weight of 28 kgs ( 1.65 kgs per spring = total 18 springs ). So I adjusted the entire distribution of springs, such that I had more springs at the back ( to support the transformer ), and less springs at the front. I did have to experiment with the spring distribution a few times, till I got the amp perfectly horizontal. Once done, there was a definite improvement in clarity and imaging to my ears. I was previously using the 'oehlbach XL Air springs" under the amps, which had improved over the stock footers. And the noob sound springs when properly placed and balanced to get the optimum compression of 3mm between the upper and lower springs, improved it even further
Sounds like the design would be much improved by boring out the holes that the springs sit in so they don't rub...wouldn't be hard to do. You wouldn't bore them out to the full depth, of course, so the ends of the springs would stay located in the centre of the bores.Note my earlier comment about these, however. They do make some mechanical noise, as the springs rub against their locating holes when they move. I tried them under my turntable and they were no good. You could actually hear the rubbing amplified through the system. Some thin PTFE sleeving or similar might work, but I couldn't be bothered...
May get them out of the drawer and have a tinker.Sounds like the design would be much improved by boring out the holes that the springs sit in so they don't rub...wouldn't be hard to do. You wouldn't bore them out to the full depth, of course, so the ends of the springs would stay located in the centre of the bores.
Apologies for the delayed reply, I've only just seen the resurrection of my thread. Thee's no bonding, no, I have simply layered the tiles and the damping. To be honest the weight of the tile(s) themselves and 43kg of speaker tends to hold them in place 😁They look great Jules👍 Can I just ask are the tiles bonded to the sound damping material so each section is solid?
