SOLD Jolida FX-10 Glass mini valve amp
Open door
1,075
119
Glos SW
In pretty good condition bar a few marks where the glass housing rests on the chassis. Hidden when the glass cage is on.
Original box and volume remote control.
Very sweet sounding 🙂
If one wants to use it without the glass cage, then feet are needed to prop it up for ventilation. The original feet holds the glass cage in and therefore protrudes through the chassis (screws into the cage).
ÂŁ330 incl U.K. post
Maximum power output: 12Wpc at 8 ohms, 1kHz
Frequency response: (1W into 8 ohms) 17Hz–37kHz +/–1dB
THD + N: Less than 1% at 10W output, 39Hz–10kHz, 8 ohms
Circuit type: Ultralinear Class AB
Tube complement: Two matched pairs of EL84 power output; two 12AX7 preamplifier
Bias settings: Self biasing
Dimensions: 8″ x 7″ x 7″
Weight: 12 lbs.
Reactions: Lawrence001
Celestion300
